Intel vPro® Platform
3049 Discussions
Intel EMA server, Create endpoints (Admin Control Mode)
lait
Hello, I have a problem with setting up endpoints.
The problem is that I can't configure the mode (Admin Control Mode), it lights up red all the time, even if I try to configure it manually.
I tried using AMD profiles, but only the HBP version is available there, which means that the client will be configured.
How to make it possible to even manually configure this functionality through MEBx?
Or if you explain how to do it, using an AMT profile would be perfect.
Thank you in advance for your messages.
MIGUEL_C_Intel
Hello, lait,
Intel complies with all applicable trade regulations and sanctions in the countries in which it operates.  Based on Intel’s announcement to cease operations in Russia, I am unable to provide the support requested.
