I'm trying to run the Intel-SA-00075 console tool to completely disable AMT. Every switch seems to work silently without user interaction except for -disableCCM - it actually prompts with a "Are you sure you want to do this?" type message - even when paired with the -noconsole switch. How to I get this to run silently without user interaction so I can deploy it via SCCM to my environment?
Oz1
Hi Oz1,
This is by design. The interaction is a preventative measure as if this is executed on the client, it completely disables CCM and it's like a one-way ticket. To re-enable CCM, the system would need to go back to the manufacturer to re-enable.
Michael
Oz1
Hi Oz1,
Michael
Excellent, thank you for the quick reply.
![](/skins/images/BC9A7A3465121B56B278007F4EE8899F/responsive_peak/images/icon_anonymous_message.png)
