Intel vPro® Platform
3049 Discussions
Invalid UUID during provisioning
cR2bi
I have encountered several instances where vPro provisioning fails on HP dc7900/8000's. The error that I receive is:
Thread:3920(DETAIL) : ACU Configurator , Category: WMI_ConfigAMT Source: Src\WMIAccess.cpp : WMI_ConfigAMT Line: 1168: The supplied data is invalid. (0xc0001c2c) ((ExecMethod ConfigAMT) The defined UUID is invalid. The UUID must include 32 hexadecimal digits and must be in the format XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX. The UUID supplied was . )
I do see in the logs that the UUID value is blank. I was wondering what would cause this issue, and how can it be resolved?
Chris C.
Bruno_Domignues
Chris,
It should be problem with UUID, but would be good double check. Run the ACUConfig with these paramenters (run as administrator) :
c:\>ACUConfig.exe /Output console Status
And see if in fact the UUID is missing.
Best Regards!
-Bruno Domingues
