Intel vPro® Platform
3045 Discussions
Remote Configuration for AMT 3.0.1 /w SCCM SP1 -
My Environment:
  • SCCM 2007 SP1 running in mixed mode on Windows Server 2003 SP2 Standard
  • Enterprise Root CA on Server 2008 Enterprise
  • Purchased provisioning certificate from Verisign as per procedure.
I've followed the 'Quick Start Install Guide for MS CfgMgr SP1 Out of Band Management Rev1_9.pdf' document to setup and configure vPro in my environment.
All of the clients I have already been deployed and are running AMT 3.0.1 (hp dc7800p's mostly), they have not been provisioned previously.
From the Quick Start guide I've installed the WS-Man translator which apparently is required to provision AMT clients prior to 3.2.1, it's from here I'm a little bit confused as to how I can remotely provision these machines without having to manually touch each one??
SCCM clients are already pushed out and functional on all these clients so I have means of remotely configuring each machine via command line.. there's several hundred machines though so manually touching each machine isn't an option..
I guess I just need the high level steps on what I need to do?? any URL's to walk through this would be greatly appreciated too!
Thanks!
Apologies - I can't delete this thread.. it turned out the ME Firmware is upgradeable from 3.0.1 to 3.2.2 for the HP dc7800's so I'm just running an SCCM job to upgrade these.. this was I won't need the WS MAN Translator..
working a treat so far!
