Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3090 Discussions
SCCM and CERTIFICATe Change problems
Hi there,
I have some strange problems.
This is the situation.
We have 3 type off hardware machines
AMT 3.2, 5.2 and 7.1 machines.
To get the 3.2 machines to work we had to have a cert from a old root verisign server to make it work.
But we started with a brand new verisign cert and this worked a first on the 7.1 machines.
Now with the new cert those provisened machines give the error not supported in SCCM.
I also have troubles connection to the console to the machnies i can power them on and off.
i check all firewall rules and settings en tested with out firewalls.
ITs a rights issue but what and with rights i am a domain admin.
Here some OOBconsole log entries.
[6][4/2/2012 1:45:33 PM] :System.Management.ManagementException\r\nInvalid parameter \r\n at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
at System.Management.ManagementPath.SetWbemPath(IWbemPath wbemPath, String path)
at System.Management.ManagementPath.CreateWbemPath(String path)
at System.Management.ManagementPath..ctor(String path)
at Microsoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlConnectionManager.GetInstance(String objectPath)\r\nManagementException details:
[5][4/2/2012 1:46:04 PM] :IMR_SOLOpenTCPSession2 with user = fail with result:0x19, description:Authentication Failed
