I am stumped here. I have downloaded the latest v7.0.11161.2 tools and I am unable to apply a security profile when using TLS as the security method. I get the error in the attached doc. I also have similar issues when using the Commander Tool to manually configure a cert and TLS. Has anyone seen this issue? Also, I thought I would install the DTK on a clean machine (WinXP SP3) and that won't even start or run.
I would really like to be able to use this in our environment, but the only way that will work is with the use of TLS and certs and right now I can't get this to work. Please help. Start from scratch as I am new to AMT and I could be missing something. However, everything works great with basic password security but not when not trying to get TLS to work. I have read a lot of documentation and watched several videos showing how to set this up using the Certificate Manager within the Director tool, but no luck.
Any help is appreciated!
Thank you,
Mark
![](/skins/images/8B5EA638CA3587CA763EE9EF53643DD4/responsive_peak/images/icon_anonymous_message.png)
