Intel vPro® Platform
2994 Discussions
iAMT and Remote Boot to Boot Menu HowTo without VNC/KVM
THatt1
I have been running an dell precision m6700 with activated iAMT 8.1.40
BIOS: SOL.on, IDE Redirect:on, Redirection Port: on)
KVM is not supported because the internal GPU is disabled by DELL.
I am using the latest "Manageability Commander Tool" from SDK.
Via context menu: "Take Control" the "Manageability Terminal Tool" is opened.
Disk Redirect Works fine
Remote Command Works also fine
I am able to modify the BIOS.
Question:
How can I come into the Windows START Menu of the iAMT Client?
If I use "Remote Reboot" or "Normal Reboot" the "Manageability Terminal Tool"
screen is black or blank.
With IPMI (other machine same windows version) is it possible to get the Windows Startmenu.
Thanks in advance
Thomas
Bruno_Domignues
In order to take control of graphic interface using vPro, you must have KVM enabled to to it.
Best Regards!
-Bruno Domingues
THatt1
thanks for reply
I am not an nativ english speaker,
but as already mentioned in the starter thread
I want to access the text console without kvm.
I have enabled kvm by the way.
But there is no sense for this, because KVM is not possible without internal GPU!
My GPU is disabled and I can't enable this feature. Is it locked by dell.
I want to use the same text console like the BIOS screen or the screen which appears
if I use Remote Command: Remote Reboot to Redirected CD ..
and I know that the console is only working in text mode via BIOS calls.
I mean this tool:
https://software.intel.com/sites/default/files/m/d/4/1/d/8/336615_336615.gif https://software.intel.com/sites/default/files/m/d/4/1/d/8/336615_336615.gif
But the diffenrence is, that there is no Intel AMT Outpost agent on the AMT machine running, because the bootloader is starting.
Bruno_Domignues
I'm not sure that I'm following you.
Basically, SOL is enabled only on character mode and you are not able to get into GUI, during a normal reboot that you are connected using SOL you lost the interface as soon Windows starts. in order to enable SOL is not required any agent installed in operating system beside MEI driver and LMS that is already wrapped by OEM.
Best Regards!
-Bruno Domingues
THatt1
It seems it is a problem with OEM DELL BIOS or/and iAMT
After Remote Reboot my terminal screen is empty all time.
