Items with no label
3340 Discussions
D435 can't reach 60FPS with PyRealsense2
SHuan76
Sorry for my poor English.
I want to record only RGB video with PyRealsense2 and opencv-python, the config is below:
config.enable_stream(rs.stream.color, 640, 480, rs.format.bgr8, 60)
But when I replayed the video I've recorded, I found that the number of frames is smaller than 60*the_time_I_spent_recording_in_seconds, in other words, the FPS is smaller than 60 (just 30 to 33).
My USB port is 3.2 and I prefer recording video with Python rather than Realsense Viewer.
Thnak you in advance for your apply.
SHuan76
Here's my code.
I run it on Jupyter Notebook. After running the code, you can see the RGB stream, press 'R' will start recording, and the stream will freeze, and press 'Q' will store the video.
import pyrealsense2 as rs
import numpy as np
import cv2
import datetime as dt
import threading as th
import multiprocessing as mp
import time
import os
class RGBRecordingClass(th.Thread):
  def __init__(self, out, queue):
    super(RGBRecordingClass, self).__init__()
    self.stop_flag = th.Event()
    self.stop_flag.set()
    self.out = out
    self.queue = queue
  def run(self):
    while self.stop_flag.isSet():
      if not self.queue.empty():
        self.out.write(self.queue.get())
    print('RGB Thread Exitted')
  def stop(self):
    self.stop_flag.clear()
pipeline = rs.pipeline()
config = rs.config()
config.enable_stream(rs.stream.color, 640, 480, rs.format.bgr8, 30)
pipeline.start(config)
directory_path = '0429'
if not os.path.exists(directory_path):
  os.mkdir(directory_path)
rgb_queue = mp.Queue()
frame_count=0
start_record = False
rgb_video_name = directory_path+'/rgb.avi'
fourcc = cv2.VideoWriter_fourcc(*'XVID')
out = cv2.VideoWriter(rgb_video_name, fourcc, 30, (640, 480))
rgb_thd = RGBRecordingClass(out, rgb_queue)
rgb_thd.start()
try:
  while True:
    # Wait for frames: color
    frames = pipeline.wait_for_frames()
    color_frame = frames.get_color_frame()
    if not color_frame:
      print('not ready')
    # Convert images to numpy arrays
    color_image = np.asanyarray(color_frame.get_data())
    if start_record:
      rgb_queue.put(color_image)
      frame_count+=1
    # Show images
    if not start_record:
      cv2.imshow('frame', color_image)
    if cv2.waitKey(10) & 0xFF == ord('r'):
      start_record = True
      print('start recording...')
      print('START TIME: '+str(dt.datetime.now()))
    if cv2.waitKey(10) & 0xFF == ord('q'):
      break
finally:
  # Stop streaming
  print('end')
  print('file saved')
  print(frame_count)
  print('END TIME: '+str(dt.datetime.now()))
  cv2.destroyAllWindows()
  out.release()
  pipeline.stop()
  rgb_thd.stop()
SHuan76
frame_count will save the total number of frames received during recording video.
And I print the time of starting recording and finishing recording, so the average fps can be calculated.
JesusG_Intel
Hello Mr. Huang,
I was able to reproduce your problem and play with your code to try different scenarios. I noticed that when I did not display the CV window output and just calculated fps, then I was able to reach 58 - 59 fps. It seems that displaying the stream causes delays in frames rendering that does not allow for the full fps to be counted in the software. Attached is a simple program that demonstrates. The frame count and FPS is printed onto the screen and stops at 500 frames.
SHuan76
Hello Jesus G.,
Sorry for my late reply,
I can reach 58-59 fps too.
I will focus on how to record video in 60 fps in the future,
but it seems to be another issue.
If I encounter another problem, I'll create a new post.
Thank you for your kind support.
