Items with no label
3335 Discussions
Fail to install RealSense SR300 with Up board Squared
NChoi
I have been tested UP Squared with RealSense SR300.
I can install following driver on Windows 10, But I [b]cannot[/b] install intel Depth Camera Manager driver due to the installer failed to detect an Intel RealSense SR300
Intel(R) RealSense(TM) Camera SR300 Depth (install succeed)
Intel(R) RealSense(TM) Camera SR300 RGB (install succeed)
Intel(R) RealSense(TM) Camera SR300 Virtual Driver(missing on Win 10)
Did anyone have same problem? Do you have any suggestion to solve this problem?
SR300 is working fine with my PC, but it fail to install RealSense SR300 with UP Squared
I believe UP Squared is powerful enough to drive RealSense SR300.
Testing detail as following:
Hardware:
Board: Up board Squared (Intel Pentium N4200 Quad Core up to 2.5 GHz, 8GB DDR4 64GB eMMC )
Camera: Intel RealSense SR300 (BlasterX Senz3D )
Tested System:
Microsoft Windows 10 Creators 1703 64-Bit
Microsoft Windows 10 Anniversary Update 1607 64-Bit
Microsoft Windows 10 Threshold 2 Update 2 (Build 10586-164) 64-Bit
Tested Driver:
Intel RealSense Depth Camera Manager sr300_3.3.27.5718
Creative BlasterX Acoustic Engine Pro Software Pack for Windows
MartyG
Up Boards usually use the R200 camera model rather than the SR300 model. This is because Up Boards use an Intel Atom x5 "Cherry Trail" processor, which R200 supports but SR300 does not.
NChoi
Thank you for your reply, I may try R200 camera.
FVice
I'm also finding the exact same issue with the UP(2) squared but with Celeron N3350 configuration. I guess there is no way around the i3 processor requirement for the SR300?
