I have tried updating firmware, and restoring factory calibration tables. Firmware update succeeds, but camera still shows same error. Calibrator fails to run (reports same above error). When reading calibration tables, I see:
CustomRW for Intel RealSense D400, Version: 2.6.4.0
Calibration parameters from the device:
resolutionLeftRight: 1280 800
FocalLengthLeft: 640.680786 640.054810
PrincipalPointLeft: 637.740173 401.552063
DistortionLeft: -0.057475 0.065094 0.000071 -0.001206 -0.020650
FocalLengthRight: 642.013062 641.501160
PrincipalPointRight: 634.743408 398.721710
DistortionRight: -0.057266 0.065141 -0.000000 -0.001148 -0.020934
RotationLeftRight: 1.000000 -0.000438 0.000322
0.000436 0.999984 0.005556
-0.000324 -0.005556 0.999985
TranslationLeftRight: -49.993645 0.122173 0.325937
HasRGB: 1
resolutionRGB: 65535 65535
FocalLengthColor: -nan -nan
PrincipalPointColor: -nan -nan
DistortionColor: -nan -nan -nan -nan -nan
RotationLeftColor: -nan -nan -nan
-nan -nan nan
-nan -nan -nan
TranslationLeftColor: -nan -nan -nan
链接已复制
I was unfortunately unable to answer this question as I have never come across this particular opcode before and was unable to find any reference information about it after extensive research.
As you have not yet received an answer from a member of the Intel support team for the three days since you posted it, I will refer this question to one of them to draw it to their attention.
This error appears in Realsense Viewer on mac 2.17.1, in a librealsense application on arm64, and in the dynamic calibrator.
realsense-viewer shows the error immediately upon adding the camera, and upon attempting to start a stream. The camera only shows "stereo module" and does not show options for a color camera.
I came here via google because I had the same error, albeit on a D430 not a D435. Other symptoms I had were an inability to read the calibration table after setting it to the factory golden (Intel.Realsense.CustomRW -g seemed to work, but Intel.Realsense.CustomRW -r said there was a bad calibration table) and when I looked at the realsense devices in Windows Device Manager, it said I had a D400 not a D430. There was no answer here, so FYI, after working with Intel Support (ultimately with Jesus G. referenced above), it turns out I had a bad connection in the interposer, and had to disconnect and reconnect it more carefully to make sure it was mounted properly, and once I did this, the module worked. So, I would suspect your D435 has either bad depth board or a bad interposer connection.
