Items with no label
3338 Discussions
RealSense SDK version 2.21.0 now available
MartyG
Hi everyone,
Version 2.21.0 of the RealSense SDK is now available for download from the link below.
https://github.com/IntelRealSense/librealsense/releases/
API CHANGES
New IR format introduced to D415 - W10:
  • Rectified, 10 bit per-pixels (packed) IR stream
  • FullHD configuration only 30 fps
  • Can be configured for use in conjunction with Depth stream (which is limited to 720p)
Available as:
  • parsed 10 bit per pixel RS2_FORMAT_Y10BPACK
  • Raw packed data (4pixel/5bytes) according to V4L2-PIX-FMT-Y10BPACK specification
NEW FEATURES & IMPROVEMENTS
  • T265 Firmware update to 0.0.18.5502 - re-localization and tracking stability enhancements
  • T265 Wheel Odometer documentation updated.
  • Android OS - add Visual Presets support.
  • Python wrapper performance enhancement - release GIL during invocation of polling routines
  • T265: Disable low power default mode.
  • Streamline Linux installation instructions. (contributed by @pedrombmachado)
  • CMake enhancements : Simplified T265 FW handling, disabling redundant downloads
BUG FIXES
  • Fix typo in Raspbian documentation (contributed by @jonherke)
  • Enable rs-measure with USB2 configurations
  • Matlab installation build fix with T265 firmware.
  • D435i: Fix D435i IMU timestamp precision
  • Fix misalignment when generating 3D Pointcloud from Depth-Aligned-To-Color
  • Fix "Elseif" statement in Matlab wrapper
  • D435i: Fix HID Timestamp trimming
  • D435i: Fix Windows Metadata script for IMU-enabled SKUs.
Full release notes with all linkages and a list of unresolved Known Issues can be viewed at the link below:
https://github.com/IntelRealSense/librealsense/wiki/Release-Notes#release-2210
