Items with no label
3338 Обсуждение
Realsense Camera does not "wakeup" after sleep
JBouc2
Начинающий
1 910Просмотр.
When my computer sleeps, the camera does not wake-up again; I need to restart my whole computer. I tried the USB huh power-management trick, but it didn't work, any ideas?
0 баллов
6 Ответы
MartyG
Почетный участник III
1 023Просмотр.
There was a case this week of a user who used their RealSense camera with both a laptop and an Intel NUC PC. The camera worked fine on the laptop, but on the NUC the camera would become unresponsive until the USB lead was unplugged and plugged back in. A Microsoft technical support person thought it may be because of outdated or incompatible driver software on the PC affected, accounting for why it worked fine on one PC but not the other.
Note that by 'drivers' the support guy did not necessarily mean RealSense drivers, since the USB sleep issue has also been reported for other devices such as USB mice, keyboards and external storage drives. It could be the PC's USB drivers that need updating.
JBouc2
Начинающий
1 023Просмотр.
Hi Marty,
Thanks for the reply. I've tried that multiple times. I think the real answer is here:
https://github.com/ideacreation/react-native-barcodescanner/pull/61/commits/7a7124e4c5894bc1ca86241905dcc062014785bd Fix black screen bug by make CameraManager a singleton by jiaminglu · Pull Request # 61 · ideacreation/react-native-barco…
But I don't know how to apply the code or use it for the fix. Is this java, do you know anything about this?
Jean
MartyG
1 023Просмотр.
Judging by the first line of the script, it is meant for use with Android smartphones, sadly.
android/src/main/java/com/eguma/barcodescanner/CameraManager.java
JBouc2
Начинающий
1 023Просмотр.
hmmm, bummer, thanks; this problem is a pain, JB
MartyG
1 023Просмотр.
Back in April, there was a case where an F200 camera was not waking after sleep. Intel support member Jose P said it was a known issue and offered a link to a site with a possible workaround.
JBouc2
Начинающий
1 023Просмотр.
Thanks much, Marty, apparently, there's officially no fix, mind boggling,
Thanks much,
Jean
Ответить
