Items with no label
3338 ディスカッション
[Realsense SDK] Merging Scan & Align Object
AHoan1
初心者
25,682件の閲覧回数
Dear,
I'm working on Realsense SDK and SR300,
1 - How to merge two PXCM3DScan or create multi PXCM3DScan in a PXCMSenseManager;
2 - Having two parts of an object, how to auto align?
3 - In PXCM3DScan, can you show me how to Reconstruct 2 PXCM3DScan to a file?
4 - Having *rssdk files of a model, how to merge?
Thanks!
71 返答(返信)
AHoan1
初心者
4,959件の閲覧回数
Dear,
Could you show me the conditions are the best that I scan a model 3D body full of R200 (range, light, configure in source code...)?
MartyG
名誉コントリビューター III
4,959件の閲覧回数
The link below has a script for the old RSSDK RealSense SDK that combines RGB and depth streams into one image. The script was for the SR300's direct predecessor the F200.but should work with SR300.
https://mtaulty.com/2015/04/16/m_15794/ https://mtaulty.com/2015/04/16/m_15794/
Regarding the best conditions for scanning a 3D model with the R200: it is not something that can be described in words precisely, because each person's location is different. In general, you should scan in a location that has average lighting (not too dark, not too bright), avoid rooms with fluorescent lights like ceiling strip lights, and position the camera so that the object / person you are scanning fills as much of the camera's view as possible.
AHoan1
初心者
4,959件の閲覧回数
I want to merge 2 rssdk files not merge RBG and Depth.
MartyG
名誉コントリビューター III
4,959件の閲覧回数
Sorry, when you said RSSDK, I thought you meant the old "RSSDK" SDKs. I do not have a clear answer for how you might merge two .RSSDK files. I can only offer this link to the last time that question was asked.
AHoan1
初心者
4,959件の閲覧回数
Dear,
Could you show me the conditions are the best that I scan a model 3D body full of SR300 (range, light, configure in source code...)?
Currently I set range is 60cm.
MartyG
名誉コントリビューター III
4,959件の閲覧回数
The same rules for getting good scan results that I mentioned earlier for R200 apply to scanning with SR300 too.
The SetIVCAMFilterOption instruction can be used in the 2016 R2 and 2016 R3 SDKs to re-balance the output of F200 and SR300 cameras according to accuracy and distance.
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?setivcamfilteroption_device_pxccapture.html Intel® RealSense™ SDK 2016 R2 Documentation
AHoan1
初心者
4,959件の閲覧回数
Dear,
How I can change configure for area of camera?
I use SDK R2 to scan model, but height is limited.
MartyG
名誉コントリビューター III
4,959件の閲覧回数
If you are scanning a human body, try clicking on the arrow at the end of the Full option to drop the menu down, and select the 'Body' option.
AHoan1
初心者
4,959件の閲覧回数
I know, but the option 'BODY' can not scanning.
Could you please try scan with option 'BODY' and take a capture for me.
I have tried so many times before and failed.
Please help me change configure of are.
MartyG
名誉コントリビューター III
4,959件の閲覧回数
Reading the 3DScan instructions, it looks like the Full option was the correct one for a full human body, as it provides the largest scanning area.
If the camera cannot see the whole body then you should move the camera further away from the body so the camera can see more of the body.
AHoan1
初心者
4,959件の閲覧回数
Code sample of intel is a deception.
AHoan1
初心者
4,959件の閲覧回数
I use SR300, if depth over 50cm, it is out of range?
MartyG
名誉コントリビューター III
4,959件の閲覧回数
Sorry, I forgot you were using an SR300 and not a R200 with much longer range. The SR390 is not suited to scanning the full human body because of its limited range. The R200 is the best camera for full body scanning. Because of the SR300's range, it is better at just scanning the head.
The only way I can think of to get depth range on the SR300 like that of the R200 is to use IVCamFilterOption to give the SR300 longer range at the expense of scanning accuracy.
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v2016r3/documentation/html/index.html?ivcamfilteroption_device_pxccapture.html Intel® RealSense™ SDK 2016 R3 Documentation
AHoan1
初心者
4,959件の閲覧回数
Dear MartyG,
Have a nice day,
When scanning a model, how to catch "lost tracking"?
I tried:
// Subscribe to receive range and tracking alerts
scan.Subscribe(OnAlert);
It does not seem to work.
AHoan1
初心者
4,959件の閲覧回数
How to check the camera does not work?
MartyG
名誉コントリビューター III
4,959件の閲覧回数
The 3D scanning function of the 2016 R2 SDK's AlertEvent system has a type of alert called ALERT_LOST_TRACKING
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?alertevent_pxc3dscan.html Intel® RealSense™ SDK 2016 R2 Documentation
The script below shows an example of use of AlertEvent.
https://github.com/getnamo/realsense-ue4/blob/master/Plugins/RealSensePlugin/ThirdParty/RSSDK/Include/pxc3dscan.h realsense-ue4/pxc3dscan.h at master · getnamo/realsense-ue4 · GitHub
AHoan1
初心者
4,959件の閲覧回数
Thank you,
I did it. I have a question:
Could you show me sample source code?
MartyG
名誉コントリビューター III
4,959件の閲覧回数
If you type 'camera explorer' into the text box at the bottom of your Windows screen (next to the button where you shut down the PC) then you can find the Camera Explorer program. This checks which RealSense cameras you have plugged in, if they can be detected, and lets you do tests with them.
AHoan1
初心者
4,934件の閲覧回数
No! That's not what I meant.
When scanning a model, camera SR300 is got stuck.
It does not work.
How to catch that case in the source code?
MartyG
名誉コントリビューター III
4,934件の閲覧回数
In the 2016 R2 SDK, AcquireFrame can be used to check if a stream has 'timed out' because it has got stuck.
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?acquireframe_pxcsensemanager.html Intel® RealSense™ SDK 2016 R2 Documentation
AHoan1
初心者
4,934件の閲覧回数
Dear,
Why is The Camera SR300 scanning then get stuck?
After I press start camera, about one-minute the camera does not work.
返信
