Items with no label
3341 Discussions
i tried to upgrad software with intel driver and support assitant but it doesn't work.
User1588237285144904
AlHill
Clear your browser cache.
If that does not work, uninstall with https://downloadcenter.intel.com/download/29376/Intel-Driver-Support-Assistant-Uninstaller?v=t
reboot
Reinstall with https://www.intel.com/content/www/us/en/support/detect.html
If that does not work, make certain you are not blocking these ports on your firewall:
IDSA accesses localhost on posts 28385-28389. It also connects to www.intel.com, downloadcenter.intel.com, and downloadmirror.intel.com, all on port 443 (HTTPS).
If that does not wor: Download, run, and ATTACH (using the paperclip under the toolbar) the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
One of the intel support engineers will help you.
By the way, you are in the wrong forum.
Doc
