- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
using this commit lavu/hwcontext_qsv: use mfxImplDescription instead of mfxExtendedDevi…
i was able to use qsv and have the session created and convert to mp4 or av1 using the commands above.
I assume it will be merged to mainline somehow and therefore see it fixed.
Thanks for the support
s7mon
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Sorry not sure why formating was broken - seems my regular browser (firefox) does not work well here.
Hi, i have recently got a ARC for video encoding to AV1.
I got it working so far and using VAAPI encoding works fine.
It is not the main GPU on the system so i need to set the QSV device manuall (works also for VAAPI).
When i try to use QSV it fails on this command
ffmpeg -loglevel verbose -i test.mp4 -qsv_device /dev/dri/renderD129 -c:v h264_qsv -global_quality 18 -rdo 1 -preset:v slow -y output.mp4
with output [AVHWDeviceContext @ 0x559be3d16d00] libva: VA-API version 1.19.0
[AVHWDeviceContext @ 0x559be3d16d00] libva: User requested driver 'iHD'
[AVHWDeviceContext @ 0x559be3d16d00] libva: Trying to open /usr/lib64/va/drivers/iHD_drv_video.so
[AVHWDeviceContext @ 0x559be3d16d00] libva: Found init function __vaDriverInit_1_19
[AVHWDeviceContext @ 0x559be3d16d00] libva: va_openDriver() returns 0
[AVHWDeviceContext @ 0x559be3d16d00] Initialised VAAPI connection: version 1.19
[AVHWDeviceContext @ 0x559be3d16d00] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 23.3.2 ().
[AVHWDeviceContext @ 0x559be3d16d00] Driver not found in known nonstandard list, using standard behaviour.
[AVHWDeviceContext @ 0x559be3d16800] Use Intel(R) oneVPL to create MFX session, API version is 2.9, the required implementation version is 1.3
[AVHWDeviceContext @ 0x559be3d16800] Error adding a MFX configurationVendorID property: -9.
Device creation failed: -1313558101.
Failed to set value '/dev/dri/renderD129' for option 'qsv_device': Unknown error occurred
(full log attached)
I can run oneVPL sample decode and clinfo looks good as well. Do i have an error in how i prepare the command for hardware use?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Adding versions of drivers etc. as well as some dmesg excerpt (which to my understanding schows that GuC and HuC firmware loaded ok)
oneVPL-intel-gpu 23.3.2
libva-intel-media-driver 23.3.2
intel-mediasdk 23.2.2
intel-graphics-system-controller 0.8.9
intel-graphics-compiler 1.0.14062.11
intel-compute-runtime 23.22.26516.18
mesa 23.1.6
libva-intel-driver 2.4.1-r4
oneVPL 2023.3.1
dmesg:
1.106798] i915 0000:32:00.0: [drm] Using a reduced BAR size of 256MiB. Consider enabling 'Resizable BAR' or similar, if available in the BIOS.
[ 1.124122] i915 0000:32:00.0: [drm] Finished loading DMC firmware i915/dg2_dmc_ver2_08.bin (v2.8)
[ 1.128748] i915 0000:32:00.0: [drm] GT0: GuC firmware i915/dg2_guc_70.bin version 70.8.0
[ 1.128760] i915 0000:32:00.0: [drm] GT0: HuC firmware i915/dg2_huc_gsc.bin version 7.10.3
[ 1.140655] i915 0000:32:00.0: [drm] GT0: GUC: submission enabled
[ 1.140664] i915 0000:32:00.0: [drm] GT0: GUC: SLPC enabled
[ 1.140916] i915 0000:32:00.0: [drm] GT0: GUC: RC enabled
[ 1.166421] [drm] Initialized i915 1.6.0 20201103 for 0000:32:00.0 on minor 1
[ 1.167407] i915 0000:32:00.0: [drm] Cannot find any crtc or sizes
[ 1.167696] i915 0000:32:00.0: [drm] Cannot find any crtc or sizes
[ 1.167717] i915 0000:32:00.0: [drm] Cannot find any crtc or sizes
[ 1.587615] i915 0000:32:00.0: [drm] GT0: HuC: authenticated for all workloads
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thank you for sharing the details. To assist you better, could you please provide the overall system requirements( OS,Processor,Graphics card if any etc.) details.
Thasneem Vazim
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Sure.
OS: Linux (Gentoo stable with selected unstable packages (see above)).
Kernel: 6.5
Mainboard MSI MEG X570 ACE
CPU: AMD Ryzen 7 3700X
GPU1: Radeon RX 5700
GPU2: Intel Arc 380
Memory 32 GB
If you need any more details let me know which.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks for providing the information.
We are checking on this internally. We will get back to you soon with an update.
Thasneem Vazim
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
We have escalated your issue to the development team, and they require the following details for further analysis:
a) The reason for explicitly setting to qsv_device renderD129.
b) Confirmation on whether this device is supported by ffmpeg or not.
Thasneem Vazim
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Sure
a) i am setting the device directly as it is currently not the default graphics card in that system.
b) I use the same approach with VAAPI (instead of QSV) to select the device which works.
It is also documented here at the end of the transcoding section
trac.ffmpeg.org/wiki/Hardware/QuickSync
trac.ffmpeg.org/ticket/7649
best regards
s7mon
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thank you for providing the details. We have conveyed this information to the development team and will reach out to you once we receive their feedback.
Thasneem Vazim
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
s7mon
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Glad to know that your issue is resolved. Thanks for sharing it with the community. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thasneem Vazim
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
