- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I have a hardware i9-9900k with widows 10 sdk.
I have installed Media SDK 2019R1.
ffmpeg latest 4.2 sdk.
My problem is when I set pix_fmt = nv12, avcodec_open2 returns the 0 value. But if I set pix_fmt AV_PIX_FMT_BGRA it returns -22.
Please help me why it didn't support AV_PIX_FMT_BGRA.
In sample code of Intel encode it is support bgra format.
AVBufferRef *encode_device = NULL;
AVCodecContext * Codec_Context_GPU;
int ret = 0;
const AVCodec *codec;
avcodec_register_all();
AVHWDeviceType Device_Type = AV_HWDEVICE_TYPE_QSV;
ret = av_hwdevice_ctx_create(&encode_device, Device_Type , NULL, NULL, 0);
codec = avcodec_find_encoder_by_name("h264_qsv");
Codec_Context_GPU = avcodec_alloc_context3(codec);
Codec_Context_GPU->bit_rate = 2000000;
Codec_Context_GPU->width = 1920;
Codec_Context_GPU->height = 1080;
Codec_Context_GPU->framerate.num = 25;
Codec_Context_GPU->framerate.den = 1;
Codec_Context_GPU->time_base.num = Codec_Context_GPU->framerate.den;
Codec_Context_GPU->time_base.den = Codec_Context_GPU->framerate.num;
Codec_Context_GPU->hw_device_ctx = av_buffer_ref(encode_device);
Codec_Context_GPU->pix_fmt = AV_PIX_FMT_NV12;//AV_PIX_FMT_BGRA;//AV_PIX_FMT_NV12;
ret = avcodec_open2(Codec_Context_GPU, codec, NULL);
if (ret < 0)
LogException(L"Could not open codec: %s\n");
- Etiquetas:
- Development Tools
- Graphics
- Intel® Media SDK
- Intel® Media Server Studio
- Media Processing
- Optimization
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Dhrumil,
In case of MSDK sample code, it supports BGRA because it configures the color conversion function of VPP at the output of debug. The decoder as an independent module can only output NV12.
Hope this helps.
Mark
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Dhrumil,
Hope this helps.
Mark
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thanks Liu Mark for reply.
Can I take BGRA Raw frame into ffmpeg encoder using vpp?
If yes, Could you provide sample code for that.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Dhrumil,
I don't use ffmpeg a lot and this forum is for Media SDK only, but I found following command, I hope useful:
> ffmpeg -init_hw_device qsv=qsv:MFX_IMPL_hw_any -hwaccel qsv -filter_hw_device qsv -vcodec h264_qsv -i input-file -acodec aac -ac 2 -b:a 48k -vcodec h264_qsv -b:v 2000k -vf "hwupload=extra_hw_frames=10,scale_qsv=960:720" -g 25 -r 25.0 -f flv > output-file
I got this from following post:
https://lists.ffmpeg.org/pipermail/ffmpeg-user/2018-June/040279.html
Let me know if this helps.
Mark
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thanks for reply Liu,
This is a ffmpeg command line (File based) for intel qvc. We need stream based ffmpeg code lines just like mention above.
Once again thanks for try to find out ffmpeg lines.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
