sample_decode h264 MFXVideoDECODE_Init return MFX_ERR_UNSUPPORTED
ll_v_
HI
I modified the sample_decode to realize the simultaneous decoding of multiple H264 files,but one of the them return  MFX_ERR_UNSUPPORTED when call  MFXVideoDECODE_Init .Why MFXVideoDECODE_Init failed and return  MFX_ERR_UNSUPPORTED ?
Bjoern_B_Intel
can you share your code so I can look at it?
Thanks & Best,
Bjoern
ll_v_
Hi Bjoern I share the main code of my decoding part.
Liu__Chao
Hi there,
Are you able to find anything yet?
I just upgraded to 2017 and found my code doesn't work any more.
I am using ffmpeg on Linux. The same code works with 2016. I just replaced these binaries from 2016 with 2017 and now MFXVideoDECODE_Init returns -3 (MFX_ERR_UNSUPPORTED)
Liu__Chao
It's caused by 2017 doesn't support 4th gen CORE. This is really sad... Is Intel trying to use this to persuade people to buy the new CPUs?
Anna_B_Intel
Hi Yjl,
You are right MSS 2017 doesn't supports Haswell.
Hi Ll,
Did sample_decode work well before you edited it? What hardware/driver do you use?
Best wishes,
Anna
