HI
I modified the sample_decode to realize the simultaneous decoding of multiple H264 files,but one of the them return MFX_ERR_UNSUPPORTED when call MFXVideoDECODE_Init .Why MFXVideoDECODE_Init failed and return MFX_ERR_UNSUPPORTED ?
can you share your code so I can look at it?
Thanks & Best,
Bjoern
Hi there,
Are you able to find anything yet?
I just upgraded to 2017 and found my code doesn't work any more.
I am using ffmpeg on Linux. The same code works with 2016. I just replaced these binaries from 2016 with 2017 and now MFXVideoDECODE_Init returns -3 (MFX_ERR_UNSUPPORTED)
It's caused by 2017 doesn't support 4th gen CORE. This is really sad... Is Intel trying to use this to persuade people to buy the new CPUs?
Hi Yjl,
You are right MSS 2017 doesn't supports Haswell.
Hi Ll,
Did sample_decode work well before you edited it? What hardware/driver do you use?
Best wishes,
Anna
![](/skins/images/8B5EA638CA3587CA763EE9EF53643DD4/responsive_peak/images/icon_anonymous_message.png)
