A CPU Upgrade
InsanityVortex
I have the Gigabyte H110M-A-CF with an Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz 3.70 GHz, I'm looking to get a better one but I don't know which one is compatible. I've been told this model motherboard only supports the 6th and 7th generation.
Where can I look?
pressed_for_time
Valued Contributor II
Yes, this motherboard does support Intel 6th and 7th generation CPUs.
A full list of processors is available from the Gigabyte support page for the H110M-A which can be found here. Although not specific to your model this list applies to all motherboards that use the Intel H110 chipset.
InsanityVortex
Good. I've just emailed a carrier in my region, asking for information on the i5 ones. I can't believe how complicated these CPU's are.
Much appreciated.
