CPU best choice
Empleados
2.832 Vistas
In attempt of wanting to build my own PC I am wanting to find out what is it I really need in terms of a CPU. The use of the computer will be to run a Virtual Lab (Cisco) as well as other Virtual Machines. For example: I would like to run Linux and Windows at the same time. Just switch from one to another by the click on a window -no reboot-. The use for each operating system will just be for most part regular browsing (emails, news, youtube, etc). I don't game.@
With this being said, I am rather confused as of what CPU I should go for. I am pretty sure I should go for either an i5 or i7; but there are so many different types within that I am confused, hence the questions below for more clarity:
I have taken a screenshot with an arrow on what I am not sure:
1. 4690K?
2. 88W?
3. L2/L3 Cache?
Thanks!
0 kudos
1 Solución
AlHill
Superusuario
1.410 Vistas
It is my opinion that building a PC starts with selecting a motherboard that supports a socket, memory, video or add-on card, and I/O ports that you want. Once you find a recent or current board, then selection of the processor can begin. Then, select an appropriate power supply.
Regarding the terms you want to know the meaning of, just hover over the term in this processor specification (as an example):
http://ark.intel.com/products/80811/Intel-Core-i5-4690K-Processor-6M-Cache-up-to-3_90-GHz Intel® Core™ i5-4690K Processor (6M Cache, up to 3.90 GHz) Specifications
To search for processors for a specific socket, use this: http://ark.intel.com/Search/Advanced ARK | Processor Feature Filter
Regarding a comparison to AMD, you will need to search other websites for that information. Of course, you know Intel and AMD processors do not use the same socket.
And, there is no "best" processor. There are many processors that will satisfy your needs. Perhaps the processor feature filter above can help you.
Lastly, the i5-4690k is already two generations back. I personally would look for a 6th generation processor supported by a current motherboard. And, I would be inclined to go with an NVidia or AMD/ATI video card as opposed to any onboard graphics.
Doc
Ver la solución en mensaje original publicado
3 Respuestas
Empleados
1.410 Vistas
By The way, I need 64 GB. Just FYI for recommendations on what CPU I should get.
AlHill
Superusuario
1.411 Vistas
Doc
Responder
