16826 Discussions
Core i5-4460 core settings
ddavi36
Recently, I downloaded the Intel XTU to play with the processor advanced settings and stress test it. After tweaking something my system became unstable and sometimes won't boot at all. I eventually reset the BIOS and everything went fine again. I noticed that some settings like Turbo Boost Short Power Max and Turbo Boost Power Time Window not available in the BIOS, only in XTU. So I want to make sure that my processor settings in all correct, default settings.
Turbo Boost Short Power Max - 105 W
Turbo Boost Power Time Windows - 0.25 seconds
Core voltage - 0.9V
Cache voltage - 0.95V
iGPU voltage - 0.9V
Core/cache voltage mode - Static (can't change to adaptive)
Graphics voltage mode - Adaptive
Please tell me if this is the default value.
The only way to set processor default settings would be loading "BIOS default". This is usually by hitting F9 key at bios level.
I recommend checking with the board maker for any other adjustment you need to do in the BIOS.
Please bear in mind the processor model i5-4460 is a locked unit. It will better to work with default values.
Allan.
