16774 Discussions
Default i5-4690K fails frequency test
TIsak
Débutant
5 543 Visites
I am trying to figure out why my Core 0 (4 total) runs at 100%, rest at around 10-20%. I installed and ran the Processor Diagnostic Tool and it failed the CPU frequency section.
I had my computer "tuned" in the BIO provided by Asus, from Default to Performance. Now i've returned everything back to default, ran test again and it still fails.
Anyone got any good advice? Is the core damaged, or is there something wrong in my setup?
Screenshot of one of the spikes http://puu.sh/mN7Mp/8911bf026b.png http://puu.sh/mN7Mp/8911bf026b.png. I have these issues while streaming, or then playing Terraria (no other game than Terraria, what i've noticed)
--- IPDT64 - Revision: 3.0.0.23.W.MP
--- IPDT64 - Start Time: 28.1.2016 20:55:07
Processor 1
Intel(R) spbc Module Test
Module Version: 1.0.7.64b.W
Start Time: Thu Jan 28 20:55:07 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
End Time: Thu Jan 28 20:55:07 2016
Total Time: seconds: 0
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Start Time: Thu Jan 28 20:55:08 2016
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Thu Jan 28 20:55:08 2016
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 62 degrees below max
CPU Brand String Test
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
Module - CPUFreq.exe did not create a results file.
--- IPDT64 - Temperature Monitor Results
Temperature Monitor will begin when CPULoad Test starts
Temperature Monitor Stopped
System Information
Processor Name: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
Processor Information: Intel64 Family 6 Model 60 Stepping 3
Number of Physical Cores: 4
Number of Logical Cores: 4
Installed System Memory: 16 GB
Operating System: Microsoft Windows 7 Professional 64-bit
Graphics Information: NVIDIA GeForce GTX 750 Ti
System Product: Z97-P
System BIOS: 2104
System Serial Number: System Serial Number
--- IPDT64 - End Time: 28.1.2016 20:55:08
--- IPDT64 - Result: Fail
FAIL
0 Compliments
11 Réponses
WSkow
Débutant
4 054 Visites
I have simmilar issue with 6600k after updating Processor Diagnostic Tool to 3.0.0.23 on Windows 10
It seems it fails on getting System Serial Number.
System Information
Processor Name: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
Processor Information: Intel64 Family 6 Model 94 Stepping 3
Operating System: Microsoft Windows 10 Pro 64-bitowy
Graphics Information: Intel(R) HD Graphics 530
System Product: Z170A GAMING M3 (MS-7978)
System BIOS: A.30
System Serial Number: Default string
--- IPDT64 - End Time: 29.01.2016 13:50:23
0 Compliments
EstebanA_C_Intel
Employé
4 054 Visites
Hello, Enimas:
I was checking the Terraria support page and they added what they called "Multicore Lighting" this was added in the patch 1.2.3 and it is a feature you can enable at the options menu, I would like you to check this option out and see the behavior of core 0.
Look for the feature added and make sure you have this or higher version of the patch: http://terraria.gamepedia.com/1.2.3 http://terraria.gamepedia.com/1.2.3
Also, make sure all cores are enabled a BIOS level.
Another options you can check is the power management for your CPU.
How to check this?
1. Access the power options in your computer, found in control panel.
2. Go to "Change advanced power settings" the window below should appear.
3. Look for Processor power management, as in screenshot below.
Additionally, you can reseat your CPU cooler to make sure it is properly installed. Re-applying thermal paste could also help.
CwaniAK, have you tried removing completely the i Intel® Processor Diagnostic Tool from your computer and the re-installing the tool? I think this could be an installation error.
I look forward to your outcome with this.
Esteban C
0 Compliments
WSkow
Débutant
4 054 Visites
It didn't help.
I have just noticed "Module - CPUFreq.exe did not create a results file." There is a thread about this already -
Here is a full raport:
--- IPDT64 - Start Time: 01.02.2016 18:53:42
Processor 1
Start Time: Mon Feb 01 18:53:42 2016
Test Result - PASS
Processor Brand String: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
End Time: Mon Feb 01 18:53:42 2016
Test Result - PASS
Temperature Test
Test Result - PASS
Received: 75 degrees below max
Test Result - PASS
Detected: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
System Information
System BIOS: A.30
--- IPDT64 - End Time: 01.02.2016 18:53:42
0 Compliments
EstebanA_C_Intel
Employé
4 054 Visites
Hello:
You can disable this test in the tool, please do it and run the test again to check if it can finish or encounters with any additional issue.
Have you tested with third party CPU health software?
This could be either a problem with the CPU or the tool.
I look forward to your reply.
Esteban C
0 Compliments
TIsak
Débutant
4 054 Visites
I changed the settings in Terraria to use quad core functions, no change.
I already checked those power settings from other topics i found, so they are according to the info you gave.
I also went in to the BIOs and found the core being on "synchronize all cores", removed it and put all 4 cores on "auto".
Now i managed to do a full computer virus scan (this has also overheated/crashed my core), and it went smoothly. Quite a few spikes up to 95%, some 100%, but didnt get bluescreen.
After the BIOs change Terraria still is at occasional 100% on Core 0. I will reinstall the core during the weekend, hoping its thermal paste issue. What other reasons can there be?
0 Compliments
WSkow
Débutant
4 054 Visites
I have only tested it with previus version of PDT. And back then it has passed all the tests. Although it has decteced wrong cpu frequency - it showed 5.2Ghz. It seemed like it was multiplying wrong bus speed (133 instead of 100) that would explain why it have shown 5.2 (39*133) instead of 3.9 (39*100).
Now it also fails on PCH test: Error while retrieving SATA Device Information from OS
Here is a full report:
--- IPDT64 - Start Time: 03.02.2016 00:18:26
Processor 1
Start Time: Wed Feb 03 00:18:26 2016
Test Result - PASS
End Time: Wed Feb 03 00:18:26 2016
Test Result - PASS
Temperature Test
Test Result - PASS
Received: 78 degrees below max
Test Result - PASS
Floating Point Test
Module Version: 1.0.10.64b.W
Start Time: Wed Feb 03 00:18:27 2016
Test Result - PASS
Million Floating Points per Second, MFLOPS: 604.8
Error: 0
--- Floating Point Test Passed!!!---
End Time: Wed Feb 03 00:18:29 2016
Total Time: seconds: 2
Prime Number Generation Test
Start Time: Wed Feb 03 00:18:29 2016
Test Result - PASS
Operation Per Second: 7.31037e+006
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Wed Feb 03 00:18:31 2016
Cache Test
Start Time: Wed Feb 03 00:18:31 2016
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 6144
Cache Size Test Passed!!!
MMXSSE Test
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
AVX Test
Module Version: 1.0.11.64b.W
Test Result - PASS
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> Yes
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supported --> Yes
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
IMC Test
Start Time: Wed Feb 03 00:18:32 2016
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 16.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Stress Test Passed!!!
End Time: Wed Feb 03 00:18:32 2016
PCH Test
Module Version: 1.0.9.64b.W
Test Result - FAIL
Chipset : Skylake Platform Controller Hub
18 device connected to PCI-to-PCI Bridge Controller
1 : Standardowy mostek CPU hosta PCI
2 : Intel(R) HD Gr...
0 Compliments
EstebanA_C_Intel
Employé
4 054 Visites
Hello, Enimas:
My recommendation would be to perform a BIOS update if not in the latest version already and the other option would be to test your system with a different Motherboard or contact your mobo's manufacturer for further troubleshooting.
PCH would be related to a board function.
Esteban C
0 Compliments
WSkow
Débutant
4 054 Visites
I have already updated bios to newest build i got from MSI today.
After reinstalling Rapid Storage Technology PCH test is not failing anymore. I have reinstalled Serial IO, Chipset Device Software and Management Engine Components aswell.
But i'm geting failed CPU Frequency test still.
When i have increased % High/Low Tolerance in test to 100% (not even 99, i has to be 100% on both) only then it is a pass.
CPU Frequency Test
Module Version: 1.0.14.64b.W
Start Time: Wed Feb 03 22:54:42 2016
Test Result - PASS
Expected CPU Frequency: 3.50
Detected CPU Frequency: 3.90002
Expected Base Clock: 100
Detected Base Clock: 100
QPI link rate Test - Not supported.
Skipping QPI link rate Test.
End Time: Wed Feb 03 22:54:43 2016
Total Time: seconds: 1
0 Compliments
EstebanA_C_Intel
Employé
4 054 Visites
Hello, CwaniAK:
It should be set to 5 both, are you using the latest Intel® Processor Diagnostic Tool?
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool-64-bit- Download Intel® Processor Diagnostic Tool
Esteban C
0 Compliments
WSkow
Débutant
4 054 Visites
Of course it should be set to 5%. What I was saying is that CPU Frequency test ONLY passes IF both High and Low Tolerance is set to 100%, it fails otherwise.
Yes, I'm using leatest version of PDT.
In linux version of PDT (its older version) test is a pass, and as i suspected: it detects wrong bus speed (133 instead of 100) which ends up in wrong detected CPU frequency.
Seems that I cant compile leatest version on linux, without Intels c++ compiler, so i cant debug it and say where and why this test is failing.
Anyway it looks like a software issue, becouse there is a bunch of people with 6600k and the same problem.
0 Compliments
EstebanA_C_Intel
Employé
4 054 Visites
Hello, CwaniAK:
I understand, just wanted to check 5 was set in your Intel® Processor Diagnostic Tool.
Let me get this issue into investigation, I will be providing you with the outcome on this.
Esteban C
0 Compliments
Répondre
