16871 Discussions
How to verify an Intel PTT endorsement key certificate
dhdj
My cpu is a i9-14900K I've exported the ek cert using the powershell commands
$a=Get-TpmEndorsementKeyInfo
$a.manufacturerCertificates|Export-Certificate -filepath "D:\Downloads\test.cer"
but it is a self signed certificate signed with the private ek, I've also tried computing the pub hash and using https://ekop.intel.com/ekcertservice/ but it returned
{"message":"Forbidden"}
 I've noticed CN = CSME ADL PTT 01SVN but I have no idea where to find the certificate for this. How should I verify the certificate chain on the intel ptt ek certificate?
for example on AMD they have http://ftpm.amd.com/pki/aia/ and their ek cert comes with authority info that points to their certificate chain and easily verifiable.
liranper
Hello @dhdj and @Andox
Starting 11th gen core, Intel PTT Endorsement Keys are certified using the Intel ODCA (On Die Certificate Authority) and no longer through EK Online Provisioning server (EKOP).
In order to walk through the certification path, you will need to obtain the embedded intermediate CAs (EICA) as described in
TCG's EK Credential Profile section 2.2.1.5.2 "Handle Values for EK Certificate Chains".
The PTT's EKs are signed by the PTT EICA (as you saw "CSME ADL PTT 01SVN")
The PTT CA is signed by the CSME Kernel EICA, the Kernel EICA is signed by the CSME ROM EICA which finally contains an AIA URL to it's issuer as you used to..
As seen in the TCG EK Credential Profile, you will find the PTT, Kernel and ROM EICA in the NV range allocated for EK chain.
On windows you can use the optional tpmdiagnostics feature to read the embedded intermediate chain:
# Install TPM Diagnostic tool optional windows feature:
PS C:\> tpmtool oc add
# Check EICAs exists in NV:
PS C:\> tpmdiagnostics ekchainnv
# Read certificates as text (read all indices in chain range and stop when NV index is not defined, in your ADL device, 0x01c00101 should not be defined since the chain fit into one TPM NV index):
PS C:\> tpmdiagnostics ReadNVIndex 0x01c00100 > nv_0x01c00100.txt
PS C:\> tpmdiagnostics ReadNVIndex 0x01c00101 > nv_0x01c00101.txt
Note that the above will output the certificate chain (concatenated ROM || Kernel || PTT EICAs) in text and not in DER/PEM. and will need some hex editor to convert.
another option is to look in the registry under:
“HKLM\SYSTEM\CurrentControlSet\Services\TPM\WMI\Endorsement\IntermediateCACertStore\Certificates”
Please let me know if this information helps and if you have more questions
Andox
I have the same question. If you have figured it out, please share how you obtained the issuer certificate(s).
ACarmona_Intel
Hello Andox,
You may continue monitoring this case to keep you updated or file a new case so that we can properly support you.
Intel Support: https://www.intel.com/content/www/us/en/support.html
Thank you for your understanding, and have a great day ahead.
Carmona A.
ACarmona_Intel
Hello Dhdj,
I will raise the case with our engineers so we can provide you with the appropriate answer to your query.
Thank you for your patience!
Carmona A.
LaserLord
Hello Intel,
I too am experiencing tremendous frustration with this issue. Has there been any update on this?
Laser Lord
ACarmona_Intel
Hello LaserLord,
The same advice that I have provided to  @Andox  is that you may continue monitoring this case to keep you updated or file a new case so that we can properly support you.
Carmona A.
ACarmona_Intel
Hello Dhdj,
Thank you so much for patiently waiting on our response.
Could you kindly provide the make and model of your motherboard? since the Trusted Platform Module (TPM) is a critical security component that can be either physically present on your motherboard or integrated within your processor. It's possible that the TPM has been disabled in the firmware settings by the manufacturer. Since your processor is compatible with Intel® Trusted Execution Technology, enabling the TPM may be necessary for optimal security performance.
For further information, we also recommend reviewing the following articles, which offer detailed insights into TPM and its functionalities:
We will be waiting for your response!
Carmona A.
dhdj
motherboard: ASUS ROG STRIX Z790-E GAMING WIFI (Nuvoton NCT6789D)
tpm (intel ptt) is enabled, secure boot is enabled, bitlocker is enabled.
As you can see the certificate is issued by Intel and it does not have a certificate chain.
PS C:\Users\dhdj> Get-TpmEndorsementKeyInfo -HashAlgorithm SHA256
IsPresent                : True
PublicKey                : System.Security.Cryptography.AsnEncodedData
PublicKeyHash            : b42b7600978cb39723cdd2508ec63796c21618651f0a0f96f98258b29caa21fb
ManufacturerCertificates : {[Subject]
                             TPMVersion=id:02580012, TPMModel=ADL, TPMManufacturer=id:494E5443
                           [Issuer]
                             CN=CSME ADL PTT  01SVN
                           [Serial Number]
                             7A0A82DDA276FE1C32098160606822AC
                           [Not Before]
                             6/22/2021 7:00:00 PM
                           [Not After]
                             12/31/2049 5:59:59 PM
                           [Thumbprint]
                             9ADE39C8C3D255417DEBFBFC77B2CAE81148D83C
AdditionalCertificates   : {}
The Common Name of the Issuer is CSME ADL PTT 01SVN which resembles something from intel, but there is no way to obtain this certificate thus the certificate chain is not verfiable.
ACarmona_Intel
Hello Dhdj,
Thank you so much for the quick response and for providing us with the complete model of your motherboard along with other relevant information that will help in our investigation.
I will now raise the case again with our engineers so they can further guide us on our next steps. And I will update you as soon as I have our engineer's response.
Again, thank you so much for your patience!
Carmona A.
Andox
Any update on this issue? We need all the public root and intermediate certificates for 'CSME ADL PTT 01SVN' to be able to verify the certificate chain.
ACarmona_Intel
Hello Dhdj,
We recommend that you look up the "certification path" in the certificate".
Then, check out this article: "https://learn.microsoft.com/en-us/windows-server/identity/ad-ds/manage/component-updates/tpm-key-attestation."
If you have any questions, please let me know.
Carmona A.
ACarmona_Intel
Hello Dhdj,
We would like to know if you have any questions regarding the recommendation that we have provided.
If yes, please let me know. We would be happy to help.
Carmona A.
Andox
Hello!
The "Certificate Path" is only displaying the certificate itself with the Certificate Status: "The issuer of this certificate could not be found."
Just to iterate on the actual issue here. We need the public root and intermediate issuer certificates for "CSME ADL PTT 01SVN" to be able to verify the full certificate chain.
Best regards
ACarmona_Intel
Hello Andox,
Again, please file a new case so that we can properly support you.
By the way, please share this thread with other moderators so they can easily understand your concern and provide you with an immediate recommendation.
Carmona A.
ACarmona_Intel
Hello Dhdj,
Again, we would like to know if you have any questions regarding the recommendation that we have provided.
Carmona A.
dhdj
Thank you for your response, however it didn't address my problem.
Yes, on older intel cpus (like a Intel i7 7600u) there is a certificate path, but on 14900k at least there is no such thing, which is the problem that we've been having. As for evidence that it's missing please refer to the screenshot posted by @Andox
Is there a way for me to get direct contact with an intel engineer or is this the only place where I can ask? This entire thing looks like a big **** up by the intel engineering team to me.
Andox
Hello Acarmona!
Sorry to reply again, but it seems like you're not reading what Dhdj and I are writing. Your response, 'We recommend that you look up the "certification path" in the certificate,' is unclear. Could you expand on what you actually mean? For example, Dhdj wrote in the initial post, 'For example, on AMD they have http://ftpm.amd.com/pki/aia/ and their EK cert comes with authority info that points to their certificate chain and is easily verifiable.' They are referring to the fact that they want the certificate chain, but your reply was essentially 'please find the chain.'
Best regards
dhdj
Yeah lol basically
Me: "The certificate path is missing, how do I find it?"
Intel: "Just look for the certificate path?"
Me: "?"
ACarmona_Intel
Hello, @dhdj  and @Andox,
Thank you so much for the response.
I will clarify the query that we have with our engineers and get back to you as soon as possible.
Thank you for your patience and understanding.
By the way, I appreciate that both of you are sharing your thoughts with us; they were all highly noted.
Carmona A.
liranper
