16761 Discussions
I am trying to download a BIOS, but I am getting access denied.
PierreLaroche
I want to update the BIOS for my old NUC but the download link isn't working.
I have tried multiple browsers, operating systems, Wi-Fi, wired connections, 4G, different IPs, and using a VPN.
The problem is clearly not on my end.
The link
https://www.intel.com/content/www/us/en/download/17536/29075/bios-update-wylpt10h.html
The error
<Error>
<Code>AccessDenied</Code>
<Message>Access Denied</Message>
<RequestId>VEQ634YCGKT1ZC18</RequestId>
<HostId>
297kYcUiOefZ4G7Xh201vnX3ehEP0iVJ8yJ+CTxgVW3zwFiIPFbdVA/g4lh0++wSyfzidXX+</HostId>
</Error>
Thank you for considering my request.
VonM_Intel
Hi, PierreLaroche.
Thank you for posting in our Community.
The error message indicates 'Access Denied', suggesting there may be restrictions or permissions set on the Intel download server. I'd like to know about the model of your Intel NUC device or you may upload the Intel SSU tool. This will enable us to collect detailed information about your system setup, which could aid in identifying the underlying cause of this issue.
Looking forward to your response. Have a nice day!
Von M.
VonM_Intel
Hi, PierreLaroche.
I hope you are doing fine.
Kindly let us know if you still need assistance.
Von M.
VonM_Intel
Hi, PierreLaroche.
I trust you're doing well.
I have not heard back from you, we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
LeonWaksman
Hi @VonM_Intel ,
I assume that you didn't try to download the WY0054.bio file.  Instead your are asking for SSU Report. I can't download this file neither. So, my conclusion is that the problem is in the Intel Download Center.
Please check.
Leon
McGeeNZ
I am also having the same issue with the same file, access denied. Intel please check your permissions this not an end user issue.
n_scott_pearson
This is probably happening because there is no longer any support - including downloads - for the WY NUC.
I have a backup of this BIOS package in my archive. I have attached it.
Hope this helps,
P.S. It is just wrong - deplorable - that the Intel support agents didn't (couldn't) tell you this right away.
McGeeNZ
Legend thank you!
Yes agreed, I feel like this is a fairly straight forward fault- hopefully someone will see this soon and push it to the right place if it is a fault.
nefistopheles
thank you..luv ya
