16759 Discussions
I recently purchased an i7 12700k i don't know how to enabled the integrated graphics
PiaKaZ
i tried checking in my Asus tuf Z790 bios cant seem to find the option to enabled it. and i also tried downloading the graphics driver for the Motherboard and doesnt workcpucpuIntel(R) Graphics Driver Installer 2024-12-26 8_15_09 PM.png
pressed_for_time
Valued Contributor II
The graphics settings in an ASUS BIOS can normally be found in the Advanced Mode part of the BIOS under the Advanced->System Agent (SA) Configuration->Graphics Configuration section.
The screenshot below shows the two settings involved
Primary Display is normally set to Auto but by default iGPU Multi-Monitor is set to Disabled. Set this to Enabled and the integrated graphics will then work.
