16761 Discussions
I7 4790K best settings in bios for cooler temps?
MElbs
Hi
Is there any bios expert in the room to help me tweak my settings ti get cooler temperature on a i7 4790k, mother board asus maximus ranger 7?
Would like to know about vcore management (offset. Adaptive..) and the different values and power management to have better cooling and performance. I don't plan to OC.
My rig:
i7 479Ok
motherboard : asus maximus ranger VII
GPU : EVGA 1080 TI FTW3
Case : phanteks enthoo Luxe
Cooler : AIO Silent Loop 360
Thanks!
Hello Asryan,
Thank you for contacting Intel Communities.
In this case, I would recommend checking the following thread/document for more information about settings you can change in the BIOS to make the system to run cooler.
Bear in mind that the information is applicable to different motherboards.
/thread/54032 How best proceed with overheating i7-4790K?
/docs/DOC-23517 Troubleshooting Intel® Core™ i7-4790K / i5-4690K overheating
I hope this information helps.
Juan V.
Hello Asryan,
Juan V.
MElbs
Wooh, long topic i will try to read that when I have time
But generally, is it better for heating to have manual, offset or adaptive ?
Hi Asryan,
Since this implies to change voltages, it means that the CPU will run out of specifications, in this case, the best I can do is to provide a 3rd party link for you to review some useful information.
http://www.overclock.net/t/1583316/adaptive-vs-offset Adaptive vs Offset?
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Juan V.
MElbs
Thanks for the help.
i tried the settings on the other topic but i have a question you can maybe answer.
When I put processor current limit at 105 :
On the stress test, no issue
On the bench i have current limit throttling.
Should i put 256 or can I leave it like this without having issue on daily using and gaming?
Hi Asryan,
I understand your question; however, I am unable to give any recommendations when talking about changing settings that may affect the CPU, that's why I provided a 3rd party website.
Juan V.
