16773 Diskussionen
IS THIS PROCESSOR UNLOCKED: Intel Xeon E5-2697 v4 Eighteen-Core Broadwell Processor 2.3GHz
DProc1
Einsteiger
5.370Aufrufe
I am trying to find out if I would be able to adjust the multiplier upwards to like 3.0, 3.2, or, even higher. The following board has only one processor socket on an Asus X99-E-10G-WS. It can handle both Non-ECC and ECC memory....Don
1 Lösung
Mitarbeiter
4.047Aufrufe
Hello Don_P,
Thank you for contacting the Intel community.
The Intel® Xeon® Processor E5-2697 v4 is not unlock, usually when you get an unlock processor you will have in the BIOS the multipliers enabled and you will be able to increase the frequency and voltage, perhaps you will be able to increase the voltage but that we don't guarantee and we don't support because Intel does not support over clocking. For overclocking you can try the following websites:
http://hwbot.org/ http://hwbot.org/
http://www.xtremesystems.org/forums/forum.php http://www.xtremesystems.org/forums/forum.php
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
The Intel® Xeon® Processor E5-2697 v4 includes many more processing and large number of cores to help this processor to handle multiple programs or heavily multi-threaded tasks.
You can see more specifications about this processor here:
http://ark.intel.com/products/91755/Intel-Xeon-Processor-E5-2697-v4-45M-Cache-2_30-GHz http://ark.intel.com/products/91755/Intel-Xeon-Processor-E5-2697-v4-45M-Cache-2_30-GHz
Best wishes,
Ivan.
Lösung in ursprünglichem Beitrag anzeigen
3 Antworten
Mitarbeiter
4.048Aufrufe
Hello Don_P,
Best wishes,
Ivan.
DProc1
Einsteiger
4.047Aufrufe
I thank you very much Ivan for your answer. I was thinking already it was the case.....Don
Mitarbeiter
4.047Aufrufe
You are more than welcome!
Ivan.
Antworten
