16766 Discusiones
Intel® Extreme Tuning Utility Package Temperature 功能??
None_
Principiante
124 Vistas
系統工具 Intel® Extreme Tuning Utility
更新內容出現錯誤,CPU溫度監視功能被改沒有了 ?????
Ver 7.14.2.45 無法正常開啟 CPU 溫度監視選項
0 kudos
1 Responder
RandyT_Intel
Moderador
41 Vistas
Hi @None_,
請注意,我只能用英語為您提供支持。我使用網絡翻譯工具翻譯了此回复,因此可能會有一些不准確的翻譯
  • Please provide the SSU log report and share it here so I can review your system's configuration.
  • When did the issue first occur?
  • Have you made any software or hardware changes to the system recently?
  • What specific error message appears when you mention "error in the update content"?
  • Does the CPU temperature monitoring show as "N/A", display zeros, or is the option completely missing from the interface?
  • Was CPU temperature monitoring working properly before updating to version 7.14.2.45?
  • Did you perform a clean uninstall/reinstall of XTU version 7.14.2.45? 10?
  • Are other XTU functions (stress testing, overclocking controls) working normally?
  • What was the last working XTU version you had installed?
  • Have you tried rolling back to a previous XTU version to confirm temperature monitoring works?
Randy T.
Responder
