16840 Discussions
Intel Management Engine Interface #1 Update
ConfinesOfFear
Hi there!
I'm really sorry if this isn't the proper place to ask such a thing!
I'm using the program CCleaner to track any outdated driver and other stuff. It pointed out that the aforementioned driver needs to be updated, saying that the last one released was on 08.15.24.
While using the Intel DSA (Intel Driver & Support Assistant), it turns out that all my PC drivers are up-to-date... but checking on internet I've found other sources mentioning the 08.15.24 update. How can it be?
I'm inclined to trust on Intel DSA, but I reaaaaaly like CCleaner since it has never ever let me down before. Plus I've found other sources saying so.
Any insights? Thanks!
AlHill
1.  It is the wrong place.
2. People still use ccleaner?
3.  You cannot update all of your PC drivers with IDSA - far from it.
4.  You can get your updated ME from your system/motherboard provider.
Now, more information is needed.  So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Fear and the desire for control are primary motivators for shadow dwellers. ]
ConfinesOfFear
Thanks for your response! There it goes.
Mavregade
I have a similar inquiry/ request. Here is the data concerning my machine. Could you please provide me the download link for the software update if such software exists?
AlHill
The latest ME version gigabyte has for your board is here:
https://download.gigabyte.com/FileList/Driver/mb_driver_chipset_300ser_heci_consumer_1914.12.0.1256.zip?v=8a972e488fd70883e82a5c07b72146e3
It is from 2019.  You shoulld contact Gigabyte regarding the latest.  However, this is an old board and gigabyte my no longer be supporting it.
I noticed your board is in legacy mode.   You might want to switch to UEFI mode.
Make sure you enable secure boot if you do switch to UEFI mode.
Your bios version is F1, the latest is F9:
https://download.gigabyte.com/FileList/BIOS/mb_bios_ga-b250m-ds3h_f9.zip?v=f7b1a19758a1880d749906bc9c4814bd
You will find all the support files and drivers for your board here:
https://www.gigabyte.com/Motherboard/GA-B250M-DS3H-rev-10/support#support-dl-driver-audio
There are likely other drivers out-of-date.  I did not check.
