16797 Discussões
Intel Management Engine exclamation mark appear in the driver
Hass12
Principiante
845 Visualizações
I have noticed there is a exclamation mark appearing next to the Intel Management Engine, upon taking a closer under the device Status, it basically say that it cannot veriy the digital signature for the driver,...might have installed a file that is signed incorrectly or damaged.
3 Respostas
pressed_for_time
Contribuidor valorado II
783 Visualizações
The manufacturer of your motherboard will provide the latest Intel Management Engine driver and also the latest firmware. Try downloading and installing the latest versions of those from the support site for your board.
Hass12
Principiante
678 Visualizações
Thank you, so I attempted to reinstall the driver from the source, but keep seeing the same message
Chris444
Principiante
522 Visualizações
Can you please share hardware IDs? attached you will find a example picture
Responder
