- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Intel NUC i3-1115G4 I installed Proxmox for my home server, but why my Intel nuc often turns itself off suddenly, when I check the syslog there is no indication of damage to the system, I suspect the power adapter, is there any other advice?
Here I attach the last syslog capture before this Intel nuc died on its own
Thank you.
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Support for the former Intel range of NUC devices is now provided by ASUS.
Your NUC would seem to be a NUC11TNKI3 - i3-1115G4. It's possible that the issue you are having might be solved by a BIOS update or a driver update. The ASUS BIOS & Firmware support page can be found here .
If that does not work then you could contact ASUS support directly about this issue, see the link on this page .
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
The bios code does not match my intel nuc, in the current bios it is PATGL357, I looked for it on the intel website but did not find it, do you know?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
PATGL357 is the name of the BIOS fitted to the 11th gen NUCs, the version number is something else. ASUS are listing a BIOS Update 0057 for NUC11PKHx / NUC11PAKx / NUC11PAQx series NUCs at this location. There is a BIOS: README file that is referenced and this seems to indicate that updating to the latest BIOS is possible. However I think you would be best to contact ASUS support and ask them for their advice as to what to do about a BIOS update.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
