17531 Discussions
Intel RMA Tray CPU Need help
Bl4nk44
My CPU is not running stably. I have the latest BIOS and the settings recommended by Intel. After checking my CPU numbers, it turned out that this is a tray CPU sold to system builders and resellers. I contacted the vendor and found out that they only offer a 24 month warranty and the warranty ended on February 28 for my CPU. What should I do now? I'm left with damaged hardware that doesn't work as it should and I don't know what I can do now.
Is it normal that Intel offers a 3 year warranty on this cpu and others may limit it to 2 years?
AlHill
There is no warranty from Intel when purchasing a gray market OEM tray processor.
Intel only provides support and wasrranty only to the system manufacturer/OEM.  So, you should contact your system manufacturer.
[W10 is this generation's XP]
Bl4nk44
I asked my system manufacturer, I got the answer that they only give 24 months warranty which passed 2 months ago. My CPU is i9 13900K
AlHill
Then, your warranty is expired.
Sorry.
