Ankündigungen
16840 Diskussionen
Intel XTU CPU Stress test not working.
Rothschild
Einsteiger
2.321Aufrufe
Hi.
For some reason Intel XTU CPU Stress test is not working with my 12900K. It just says Passed after literally 1 second. This is happening for me on 2 different version XTU's.
Not much web search results on this one, the only post I found of someone with the exact problem fixed it by using an older version XTU.
Any ideas? I think if I install XTU versions that are too old they wouldn't support the new 12th Gen.
Thanks!
3 Antworten
David_G_Intel
2.288Aufrufe
Hello Rothschild
Thank you for posting on the Intel️® communities. Please share with us the following information:
  • What version of XTU did you try?
  • Did it work properly at any point before?
  • Can you share a video of the problem to replicate it?
  • What windows version and build do you use?
  • Did you overclock the processor at any point before?
  • What motherboard model and BIOS do you use?
David G
David_G_Intel
2.270Aufrufe
David G.
David_G_Intel
2.249Aufrufe
David G.
Antworten
