16785 Discussions
Is it possible to configure Intel i7 12th gen processor as PCIe Endpoint
sujan19
We wanted to know that if it is possible to configure Intel i7 12th gen processor installed on a PCE-5133 Single board Computer as an PCIe Endpoint ?
Can this be achieved while running Ubuntu & by writing a custom driver ?
Thanks & Regards,
Sujan
Rajesh_kumar_krishnan
Hi Ramyer M
we are also facing the same issue and require your support
card : https://www.advantech.com/en/products/1-2jkp2l/pce-5133/mod_9dd4a86e-6bff-42a8-bf2f-4b8f1ccc2189
processor : 96MPI7A-2.1-25M17- CORE I7 2.1G 25M 12C 1700P I7-12700  ( https://www.advantech.com/en/products/7e17429b-a827-4726-bb7b-97613687e707/96mpi7a-21-25m17/mod_ce067573-21ff-437d-9b78-50eb267ea997)
can you please provide the method to enable this card as end point .
Scenario: We have two Advantech PCE-5133 cards. One of these cards is already configured as the root point (which is the default configuration). The other identical card will serve as the end point for memory mapping.
RamyerM_Intel
Hello sujan19,
Thank you for sharing this information. Let me coordinate this inquiry with my team and get back to you as soon as possible.
As for Rajesh_kumar_krishnan, thank you for engaging in our community. To give you the full focus of our support we highly recommend creating a new thread. I assure you that we will be on the lookout on this new thread that you will create. Thank you!
Ramyer M.
sujan19
Hi @RamyerM_Intel ,
Any updates regarding our Inquiry ?
Sujan
RamyerM_Intel
Hello sujan19,
Thank you for patiently waiting. Upon coordinating with our team, we want to let you know that questions of this nature are best addressed by our FPGA specialists. As such, I am moving this thread to our FPGA forum. You may also find it beneficial to reach out to your motherboard's OEM as well for further assistance.
Ramyer M.
intel Customer Support Technician
sujan19
Hello Ramyer,
We are using INTEL I7 12TH GEN PROCESSOR , which is completely different from your FPGA Line-up, So I don't understand how moving this thread to an FPGA forum will help us in any way ?
Sujan
ArGD
Was this ever solved? I would like to understand the same about Intel processors
sujan19
No its not possible to configure Intel processors as endpoint, as it would require modification from BIOS level as well, not just kernel.
