16850 Discussions
Is my 13900KF dying?
K1llrzzZ
Hi!
So I have had lots of BSODs on my system, like once or twice a day always in Windows, either I was in Chrome or I just left my PC turned on for a couple of hours doing nothing, came back and noticed it has restarted, checked the bluescreenview and there it was. I also had constant crashed in Chrome and other browsers like "status_breakpoint" and "status_access_violation", it has gotten so bad that sometimes I couldn't finish a 2 min YT video without Chrome crashing like 10 times. I read multiple threads about people with i9s having this same issue and the only thing that solved it is having the CPU replaced.
Example 1
Example 2
Then one day, I turned it on, BSOD in 10 min, then restarted, another and I got like 4 until it got to the point that it didn't even start, always BSOD on startup with the same message (IRQL_NOT_LESS_OR_EQUAL). I couldn't even repair or reinstall because the install has failed with BSOD as well, I was finally managed to install a copy of Windows on another drive and start up, no drivers, no internet, low resolution but I was able to use a pentdrive to copy the Intels own Diagnostics Tool. I ran it 4 times, and 2 times out of 4 it failed, it passed the other two times. Since I ran Windows Memorgy Diagnosics before and Memtest86 from my BIOS and both passed without issues it was basically confirmed that it's my CPU or so I thought. I took my PC into a friends PC repair shop so he can test stuff individually in different PCs to confirm but to my surprise he said my CPU is fine and actually it's my SSD that died and not even the one that has Windows installed on it. Apperantly it had so many bad sectors that it caused the BSODs every time a file was read from there and eventually it corrupted Windows itself.
He said the only issue with my CPU was that I had a very old BIOS, he updated it to the latest one, saved my stuff from my bad SSD to a new one, formatted my win SSD and reinstalled Windows and gave me back my PC and things seemed fine... almost... Chrome still crashes sometimes but way less then before and I did have 1-2 BSODs but way less then before and with a different error code (PAGE_FAULT_IN_NONPAGED_AREA). It was suggested to me that it might be caused by the files I saved from the old corrupted harddrive as the files themselfs could be corrupted.
Now here's the weirdest thing: I don't use my PC for a lot of stuff that puts a lot of load on the CPU except for gaming. I don't do like video-editing and run apps that use all cores so the heaviest task my CPU does is gaming. And I never had a single crash or BSOD in any game I play and I play a few different ones, most of those are new games with high system requirements. Other people that had their i9s die on them always said it crashed during gaming and heavier tasks which obviously makes sense but mine only crashed under Windows. So what's going on?
The only guess I have is that one (or more) of my E-Cores are faulty which aren't being used under gaming as that prioritizes the P cores so I don't crash during gaming but when I'm in Windows and the faulty E-Core is being used then I get a BSOD. Thoughts?
Hardware:
Asus ROG Strix Z790-F Gaming Wifi (latest BIOS right now)
RAM: G-Skill Triden 2x16GB DDR5 6400
CPU: Intel Core i9 13900KF (stock settings)
GPU: Asus TUF OC RTX 4090
PSU: Corsair HX1200
Windows 11 Pro
Edit: Oh and I ran the Intel Diagnostics Thingy since the reinstall a few times (3-4, altough never back to back) and it always passed
K1llrzzZ
For some reason I cannot upload my current dump files but I have some of the old ones saved on a pentdrive, these are from the time when my PC wasn't booting up:
Dump file
Edit: I was able to access the most recent minidump:
https://easyupload.io/32kyj1
Mike_Intel
Hello K1llrzzZ,
For us to further check this, please help provide the following details:
  1. When did you purchase the unit?
  2. Was it working fine before?
  3. Did you change any settings before the issue started?
  4. What are the troubleshooting steps that you tried so far?
Michael L.
K1llrzzZ
1.) Around the time it came out, october - novemberish 2022
2.) Yes, it was working for a long time, these issues started happening around 6-8 months ago if I remember correctly, I just wasn't sure what's causing them, I was suspecting corrupted Windows since the system was stable while under load (gaming), but since I've read about these browser crashes being caused by a dying CPU
3.) No, when I bought the CPU I left everything on auto except the RAM, I turned XMP on and that was it. System was stable for a  very long time.
4.) Reinstalled Windows, updated BIOS, replaced faulty SSD, ran Windows Memory Diagnostics (passed) and memtest86 from BIOS (passed), reinstalled Chrome and all drivers after Windows reinstall and like I said I ran the Intel Diagnostic Tool before the BIOS update and new Windows/SSD, failed 2 times out of 4, since the new BIOS and Win I ran it like 3-4 times (not back to back), passed every time.
Mike_Intel
Hello K1llrzzZ,
Thank you for the quick reply.
For the BSOD and/or stability issue, kindly open the community link where we posted our recommendations and follow the provided settings that you need to set inside the BIOS then tell us if there is an improvement.
https://community.intel.com/t5/Processors/Updated-Guidance-RE-Reports-of-13th-14th-Gen-Unlocked-Desktop/m-p/1594553
Michael L.
ACarmona_Intel
Hello K1llrzzZ,
We would like to know if you have any questions regarding the recommendation that we have provided.
If so, kindly inform me, as we would be glad to assist you.
Carmona A.
K1llrzzZ
I was able to find some of the recommended settings but not all. The ones I found I changed to what was recommended. I have an Asus ROG Strix Z-790-F Gaming Wifi mobo with a recent BIOS.
Since I changed it I haven't had a BSOD, but then again even before there were like weeks where I didn't get one its pretty random. The browser crashes however did not go away.
K1llrzzZ
I just had another BSOD yesterday, attached the dump file, same error code as before, PAGE_FAULT_IN_NONPAGED_AREA
Mike_Intel
Hello K1llrzzZ,
I am sorry to hear that. If you are still having the same issue after trying our recommendations, you need to report this to your local Warranty team. Please submit a request in the link below:
https://www.intel.com/content/www/us/en/support/contact-intel.html#support-intel-products_873:873
Michael L.
Mike_Intel
Hello K1llrzzZ,
Michael L.
K1llrzzZ
Hello, yes, I read it, I'm from Hungary, I don't know how the RMA process works here but I imagine trough the store I bought the CPU from. I'm just worried it'll take a long time and I won't be able to use my PC for a very long time and now it's still at a point where it's usable, BSODs aren't as regular but still occur, browser crashes happen more often and they're annoying but it beats having no PC at all. Then again it may get worse again, maybe the CPU is failing just hasn't failed completely yet, I don't know I'm still at a point where I'm waiting for an offical response from Intel about why these CPUs are failing and maybe it can be solved with a microcode or BIOS update or something (hopefully without sacrificing too much performance).
Mike_Intel
Hello K1llrzzZ,
I understand your worries, kindly contact your local support team so that they can explain the warranty procedure and so that you can also tell them about your situation. They may provide some options for you to resolve the issue.
Michael L.
Mike_Intel
Hello K1llrzzZ,
Michael L.
K1llrzzZ
Hello, I'm currently waiting for the announced microcode update by Intel to see if that fixes the issue. If not then I'll look into local options to RMA
Mike_Intel
Hello K1llrzzZ,
Thank you for the update.
Since you already know your next step, I need to close this inquiry.
Michael L.
K1llrzzZ
Hello, just wanted to give a quick update to help others. I updated to the latest BIOS with the microcode update and it didn't solve the issue, what did was this:
https://www.youtube.com/watch?v=afN6SaT21cQ
I didn't even have to add voltage, I just locked the cores to 55 and the crashed went aways. XMP is still on, no more  browser crashed, no more BSODs, everything works. You guys should promote this more, it would mean less people have to RMA. If my CPU stays stable this way I probably won't have to RMA either, we'll see.
