Since 2 weeks I have this problem with random BSOD occuring when I am starting games like HUNT or Fortnite or something that needs some Power. I was at the IT Support they said they fixed the thermal paste at the CPU & GPU and cleaned my PC and after over 100€ it still crashes...
My Specs:
Windows Version: Windows 11 Pro 24H2
Motherboard: Gigabyte Z790 D DDR4
CPU: 13th Gen Intel i7 - 13700KF 3400MHz 16 cores 24 logic Processors
GPU: Nvidia RTX 4080
RAM: 2 x 16GB DDR4 Kingstone RAM
1. SSD: Motherboard SSD WD Blue SN570 1TB
2. SSD: SanDisk SDSSDH3 2TB
3. PSU: 1000W BeQuiet PSU (idk where i get more information)
Crashes:
The last 9 Crashes I got so far, I am using WhoCrashed since it is easier for me to read:
DRIVER IRQL NOT LESS OR EQUAL - dxgmms2,sys had the error
SYSTEM SERVICE EXEPTION - 0x3B(0xC0000005, 0xFFFFF800DB0C73A0, 0xFFFFF08D6D5862E0, 0x0)
WHEA UNCORRECTABLE ERROR - 0x124(0x0, 0xFFFFB28C7D744028, 0xB6000000, 0x480F0150)
KMODE EXEPTION NOT HANDLED - Ntfs.sys (Ntfs + 293e8a)
KMODE EXEPTION NOT HANDLED - 0x1E(0xFFFFFFFF80000003, 0xFFFFF807B6E45386, 0x0, 0xFFFFBF8045BE89C0)
WHEA UNCORRECTABLE ERROR - 0x124(0x0, 0xFFFF828FF8043028, 0xB6000000, 0xF0150) in genuineintel.sys
DUMP FILES: [https://www.mediafire.com/file/45h2d0e8rg5pw3a/Dump\_Files.zip/file](https://www.mediafire.com/file/45h2d0e8rg5pw3a/Dump_Files.zip/file)
The last WHEA Error could be because of overheating which I fixed. The CPU is now not hotter than 60°C where it was around 100° before I changed thermal paste.
Things I have already tried:
Changed Windows Version.
Updated Graphics Driver and downgraded it to an older Version.
Updated Bios to the newest Version F14.
Build out the SSDs and used them 1 by 1, it still crashed.
I ran Memtest86 for one RUN and it didnt got any errors.
If you have any Ideas please help me.
Thank you for all your help
Hello zVayn,
Thank you for reaching out to Intel Community Forum. I understand that you are experiencing frequent kernel crashes and blue screen errors when launching games that require high performance, and I am here to assist you.
I would like to ask and confirm a few details before determining the next step. Could you please provide the following information below?
- How often does the issue occur, and when exactly does it happen (e.g., during startup, mid-game, or after prolonged use)?
- When did this issue first start happening?
- Aside from the steps you already mentioned (thermal paste replacement, driver updates, BIOS update, SSD testing, and Memtest86), have you tried any other troubleshooting methods?
- Were there any recent changes made to your system before the issue began, such as new hardware installation, software updates, or configuration changes?
- Did you overclock the processor? Please note that if the system was overclocked, including voltage or frequency beyond the processor’s supported specifications, it may void the warranty.
- Do you see any physical damage on the processor? Damage to the product indicates the product changed from its originally shipped condition and might void the warranty.
- Was the processor purchased less than 30 days ago? If so, you may try contacting the place of purchase for warranty options.
- Could you please provide the batch number and serial number of the processor? This is so I can expedite the process in case warranty validation is needed.
Thank you for your cooperation.
Kenneth B.
Hello zVayn,
I wanted to follow up regarding the questions I previously sent. Kindly share your responses when convenient so I can continue assisting you with this matter.
Kenneth B.
Hello zVayn,
As I have not received a response, I will now proceed to close this inquiry. If you require further assistance, please feel free to submit a new inquiry, as this thread will no longer be monitored.
Kenneth B.
