16766 Discusiones
Processor temperature over normal...
WalterGMS
Principiante
3.415 Vistas
Hi, i buy a I5 14600KF, the processor is getting very hot (70ºC to 80ºC) even without any task running and when I'm playing it reaches 100ºC easily.
Water Cooler Specs:
- TDP: 250W
- fan size: 120x120x25mm (3x)
- ARGB - 5v motherboard
- fan speed: 1200-2000RPM
- Bearing type: Hydraulic bearing
- Voltage: 12v
- Fan noise: 20dB(A)
- Airflow: 56.3CFM (MAX)
- Fan lifespan: 80000 Hours
Socket:
- Intel - LGA1156/1155/1151/1150/1366/2011/1200/1700
- AMD Socket - FM2+/FM1/AM3+/AM3/AM2/AM4/AM5
I have already checked all the connections between the parts, dismantled the water cooler and to check if the thermal paste is covering the entire processor and is ok, the water cooler fixing screws are well positioned and tightened without any gaps...
I'm thinking that this water cooler is not capable of cooling this processor. If this is the case, I would like suggestions for water coolers that have already been tested and that support this processor.
Intel scan attached.
0 kudos
1 Solución
AceOfSpades45682
Nuevo Colaborador I
3.270 Vistas
Hello there @WalterGMS I think Intel® Processors have built-in thermal protection. If the processor gets too hot, the built-in protection shuts down the processor. If your computer isn't overclocked and is running under the design specifications, the built-in protection can help prevent damage to your system.
Upgrading to a more capable cooler or ensuring your current cooler is properly installed and functioning optimally should help mitigate the overheating problem.
you open this link from Intel Overheating Symptoms and Troubleshooting for Intel® Boxed Processors, and What Is Throttling and How Can It Be Resolved?
hope it helps
Perkins...
Ver la solución en mensaje original publicado
4 Respuestas
AceOfSpades45682
Nuevo Colaborador I
3.271 Vistas
hope it helps
Perkins...
WalterGMS
Principiante
3.246 Vistas
Hi Perkins, thanks for the attention!
I replaced the water cooler with a Thermaltake TH360 and now its around 25° celsius idle and hits 55° gaming.
The problem was the WC.
AceOfSpades45682
Nuevo Colaborador I
3.223 Vistas
yeah.. It's a significant improvement in temperatures with your new Thermaltake TH360 water cooler compared to your previous setup. 55°C under gaming is a good temperature for a high-performance cooler. It shows that the TH360 is effectively managing the heat generated during intensive tasks. The TH360's fans are likely higher quality, designed for efficient airflow and static pressure, which is crucial for a radiator of this size. If you had issues with your previous cooler, it could have been due to: **Pump Failure: A failing pump would result in poor circulation of coolant. **Leaking or Air Pockets: These can reduce the effectiveness of the cooling solution. **Thermal Paste Issues: Old or improperly applied thermal paste can cause poor thermal transfer. **Insufficient Radiator Size: A smaller radiator or less effective cooler design might not handle high-performance CPUs well.
hope it helps
Perkins...
ShunMnzed
Nuevo Colaborador I
3.216 Vistas
Hi Walter let me add up some things... Higher idle temperatures could indicate issues with the previous cooler, such as poor pump performance, insufficient contact with the CPU, or degraded thermal paste. The TH360 you used features a 360mm radiator with three high-performance 120mm fans. This larger radiator and more fans provide superior heat dissipation compared to smaller coolers. Also to ensure the longevity and efficiency of your new cooler, consider some maintenance tips:
  1. Keep the radiator and fans clean from dust buildup to maintain airflow.
  2. While most AIO coolers are sealed, it's good to check for any signs of leaks or reduced performance.
  3. Keep an eye on temperatures to ensure that they remain within safe ranges.
  4. If your cooler has associated software, keep it updated for optimal performance and fan control.
but if you find that the TH360 might be overkill for your needs or you’re interested in exploring other options, consider:
  1. High-end air coolers can also perform very well and might be easier to install and maintain.
  2. Brands like Corsair, NZXT, and Arctic offer various models with different sizes and features.
Responder
