17248 Discussions
WHEA-Logger Event ID 1
nkok
On every boot, I got the WHEA-Logger error, event id 1. It just slow down the boot process and didn't cause BSOD.
Crash dump using WinDbg is as follows:
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
nt!_WHEA_ERROR_RECORD structure that describes the error condition. Try !errrec Address of the nt!_WHEA_ERROR_RECORD structure to get more details.
Arguments:
Arg1: 0000000000000007, BOOT Error
Arg2: ffffc101b0c26070, Address of the nt!_WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000
Arg4: 0000000000000000
Debugging Details:
Mini Kernel Dump does not contain unloaded driver list
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1078
    Key  : Analysis.Elapsed.mSec
    Value: 1201
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 312
    Key  : Analysis.Init.Elapsed.mSec
    Value: 22571
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 98
    Key  : Analysis.Version.DbgEng
    Value: 10.0.27829.1001
    Key  : Analysis.Version.Description
    Value: 10.2503.24.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2503.24.1
    Key  : Bugcheck.Code.LegacyAPI
    Value: 0x124
    Key  : Bugcheck.Code.TargetModel
    Value: 0x124
    Key  : Dump.Attributes.AsUlong
    Value: 0x18
    Key  : Dump.Attributes.KernelGeneratedTriageDump
    Value: 1
    Key  : Failure.Bucket
    Value: LKD_0x124_7_GenuineIntel__UNKNOWN_IMAGE_GenuineIntel.sys
    Key  : Failure.Hash
    Value: {5ea80f6a-69bf-5d6f-8fd2-cd87deb91a03}
BUGCHECK_CODE:  124
BUGCHECK_P1: 7
BUGCHECK_P2: ffffc101b0c26070
BUGCHECK_P3: 0
BUGCHECK_P4: 0
FILE_IN_CAB:  WHEA-20250515-1112.dmp
DUMP_FILE_ATTRIBUTES: 0x18
  Kernel Generated Triage Dump
  Live Generated Dump
FAULTING_THREAD:  ffffc101b0f560c0
PROCESS_NAME:  smss.exe
STACK_TEXT:
ffff8b03`23e81a90 fffff801`22f5f05f     : ffffc101`b0c26050 00000000`00000000 ffffc101`b0c26070 00000000`00000022 : nt!LkmdTelCreateReport+0x139
ffff8b03`23e81fd0 fffff801`22f5ef56     : ffffc101`b0c26050 fffff801`00000000 000000c1`00000000 000000c1`b07ff840 : nt!WheapReportLiveDump+0x7b
ffff8b03`23e82010 fffff801`22dd4ff1     : 00000000`00000001 ffff8b03`23e82480 000000c1`b07ff840 00000000`0000028c : nt!WheapReportDeferredLiveDumps+0x7a
ffff8b03`23e82040 fffff801`22c77707     : 00000000`00000000 ffffc101`ae941030 00000000`00000103 00000000`00000000 : nt!WheaCrashDumpInitializationComplete+0x59
ffff8b03`23e82070 fffff801`22a12005     : ffffc101`b0f50000 ffffc101`b0f3ab50 ffff8b03`23e82480 ffffc101`00000000 : nt!NtSetSystemInformation+0x1f7
ffff8b03`23e82400 00007ffe`66b10a64     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
000000c1`b07ff7e8 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffe`66b10a64
MODULE_NAME: GenuineIntel
IMAGE_NAME:  GenuineIntel.sys
STACK_COMMAND: .process /r /p 0xffffc101b0eab040; .thread 0xffffc101b0f560c0 ; kb
FAILURE_BUCKET_ID:  LKD_0x124_7_GenuineIntel__UNKNOWN_IMAGE_GenuineIntel.sys
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {5ea80f6a-69bf-5d6f-8fd2-cd87deb91a03}
Followup:     MachineOwner
The spec of my machine using Intel SSU is as attached.
Appreciate if you help to diagnose what's the root cause of the hardware error?
JedG_Intel
Hello nkok,
For me to address this properly, I'll need more information from you. Please share the information below.
1. Was this working fine before?
2. Are there any recent changes with the system?
3. What troubleshooting steps has been performed?
4. Have you checked the other components individually?
Jed G.
nkok
Hi Jed,
Actually, the WHEA-Logger event id 1 was happening since day 1 of my purchase for 1.5 years ago. Just a week ago, I decided to change the SSD due to many BSOD happened with stornvme event id 129 that freeze my laptop randomly. After changing the SSD, the hard disk freezing is now gone. But the WHEA-logger event id 1 still happen with no BSOD. Then I did further googling and got the WinDbg to debug the dump as raised in the post.
As described in 1 above.
  • Used Lenovo Vantage Commercial software to perform ALL hardware test, all pass
  •  Event id 6062, Netntw14.sys happened all the time. Thought the network card was causing the WHEA-Logger event id 1. Perform hardware test but it passed. Googled and fix it by changing the registry value.
  • Yesterday contacted Lenovo Premium Support, use the Lenovo Diagnostics Evolution and found out that the NVidia RTX3070 failed the test. Now I am waiting for part replacement on 19/5/2025.
Yes. The NVidia RTX3070 is tested faulty with  Lenovo Diagnostics Evolution. Will report back if after changing the RTX3070, the WHEA problem still persist.
NK KOK
JedG_Intel
Hello nkok,
Thank you for providing all the necessary information. As the Nvidia RTX 3070 did not pass the diagnostic test and a replacement unit is being arranged, we will pause further action for now. Please do not hesitate to inform me if the same issue recurs.
Jed G.
nkok
Hi Jed,
  After replacing the motherboard, the WHEA-Logger event id is gone, but surprisingly the NVidia RTX 3070 still failed the Lenovo Evolution Diagnostics for DirectCompute Standard Mathematical Operations Test and DirectCompute Advanced Mathematical Operations Test. Also it gives rise to new error, event id 7043: The Lenovo Intelligent Thermal Solution Service service did not shut down properly after receiving a pre-shutdown control.
  For now I think these error were not related to Intel, you can close the case.
JedG_Intel
Hi nkok,
Thank you for this update and your efforts are highly appreciated. As the issue is possibly related to a different component, I'll proceed with closing this inquiry. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jed G.
