- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
On every boot, I got the WHEA-Logger error, event id 1. It just slow down the boot process and didn't cause BSOD.
Crash dump using WinDbg is as follows:
WHEA_UNCORRECTABLE_ERROR (124) A fatal hardware error has occurred. Parameter 1 identifies the type of error source that reported the error. Parameter 2 holds the address of the nt!_WHEA_ERROR_RECORD structure that describes the error condition. Try !errrec Address of the nt!_WHEA_ERROR_RECORD structure to get more details. Arguments: Arg1: 0000000000000007, BOOT Error Arg2: ffffc101b0c26070, Address of the nt!_WHEA_ERROR_RECORD structure. Arg3: 0000000000000000 Arg4: 0000000000000000 Debugging Details: ------------------ Mini Kernel Dump does not contain unloaded driver list Mini Kernel Dump does not contain unloaded driver list KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 1078 Key : Analysis.Elapsed.mSec Value: 1201 Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 0 Key : Analysis.Init.CPU.mSec Value: 312 Key : Analysis.Init.Elapsed.mSec Value: 22571 Key : Analysis.Memory.CommitPeak.Mb Value: 98 Key : Analysis.Version.DbgEng Value: 10.0.27829.1001 Key : Analysis.Version.Description Value: 10.2503.24.01 amd64fre Key : Analysis.Version.Ext Value: 1.2503.24.1 Key : Bugcheck.Code.LegacyAPI Value: 0x124 Key : Bugcheck.Code.TargetModel Value: 0x124 Key : Dump.Attributes.AsUlong Value: 0x18 Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : Failure.Bucket Value: LKD_0x124_7_GenuineIntel__UNKNOWN_IMAGE_GenuineIntel.sys Key : Failure.Hash Value: {5ea80f6a-69bf-5d6f-8fd2-cd87deb91a03} BUGCHECK_CODE: 124 BUGCHECK_P1: 7 BUGCHECK_P2: ffffc101b0c26070 BUGCHECK_P3: 0 BUGCHECK_P4: 0 FILE_IN_CAB: WHEA-20250515-1112.dmp DUMP_FILE_ATTRIBUTES: 0x18 Kernel Generated Triage Dump Live Generated Dump FAULTING_THREAD: ffffc101b0f560c0 PROCESS_NAME: smss.exe STACK_TEXT: ffff8b03`23e81a90 fffff801`22f5f05f : ffffc101`b0c26050 00000000`00000000 ffffc101`b0c26070 00000000`00000022 : nt!LkmdTelCreateReport+0x139 ffff8b03`23e81fd0 fffff801`22f5ef56 : ffffc101`b0c26050 fffff801`00000000 000000c1`00000000 000000c1`b07ff840 : nt!WheapReportLiveDump+0x7b ffff8b03`23e82010 fffff801`22dd4ff1 : 00000000`00000001 ffff8b03`23e82480 000000c1`b07ff840 00000000`0000028c : nt!WheapReportDeferredLiveDumps+0x7a ffff8b03`23e82040 fffff801`22c77707 : 00000000`00000000 ffffc101`ae941030 00000000`00000103 00000000`00000000 : nt!WheaCrashDumpInitializationComplete+0x59 ffff8b03`23e82070 fffff801`22a12005 : ffffc101`b0f50000 ffffc101`b0f3ab50 ffff8b03`23e82480 ffffc101`00000000 : nt!NtSetSystemInformation+0x1f7 ffff8b03`23e82400 00007ffe`66b10a64 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25 000000c1`b07ff7e8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffe`66b10a64 MODULE_NAME: GenuineIntel IMAGE_NAME: GenuineIntel.sys STACK_COMMAND: .process /r /p 0xffffc101b0eab040; .thread 0xffffc101b0f560c0 ; kb FAILURE_BUCKET_ID: LKD_0x124_7_GenuineIntel__UNKNOWN_IMAGE_GenuineIntel.sys OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {5ea80f6a-69bf-5d6f-8fd2-cd87deb91a03} Followup: MachineOwner ---------
The spec of my machine using Intel SSU is as attached.
Appreciate if you help to diagnose what's the root cause of the hardware error?
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello nkok,
For me to address this properly, I'll need more information from you. Please share the information below.
1. Was this working fine before?
2. Are there any recent changes with the system?
3. What troubleshooting steps has been performed?
4. Have you checked the other components individually?
Jed G.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
- Used Lenovo Vantage Commercial software to perform ALL hardware test, all pass
- Event id 6062, Netntw14.sys happened all the time. Thought the network card was causing the WHEA-Logger event id 1. Perform hardware test but it passed. Googled and fix it by changing the registry value.
- Yesterday contacted Lenovo Premium Support, use the Lenovo Diagnostics Evolution and found out that the NVidia RTX3070 failed the test. Now I am waiting for part replacement on 19/5/2025.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello nkok,
Thank you for providing all the necessary information. As the Nvidia RTX 3070 did not pass the diagnostic test and a replacement unit is being arranged, we will pause further action for now. Please do not hesitate to inform me if the same issue recurs.
Jed G.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi Jed,
After replacing the motherboard, the WHEA-Logger event id is gone, but surprisingly the NVidia RTX 3070 still failed the Lenovo Evolution Diagnostics for DirectCompute Standard Mathematical Operations Test and DirectCompute Advanced Mathematical Operations Test. Also it gives rise to new error, event id 7043: The Lenovo Intelligent Thermal Solution Service service did not shut down properly after receiving a pre-shutdown control.
For now I think these error were not related to Intel, you can close the case.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi nkok,
Thank you for this update and your efforts are highly appreciated. As the issue is possibly related to a different component, I'll proceed with closing this inquiry. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jed G.
