16774 Discussions
best ram for intel ultra 9 285k
jmitura
Hello what would be best fastest ram for not overclocked intel ultra 9 285k with gigabyte AI top motherboard.
I am a bit confused as recently very fast DDR5 cudimm ram are marketed as to be used with newest intel , but specification suggests that max is 6400 MHz am I missing something?
pressed_for_time
Valued Contributor II
Your motherboard will have an XMP option in the BIOS. XMP is Intel® Extreme Memory Profile. By default this option is set to DISABLED, setting it to ENABLED will allow faster memory speeds than standard. This will for example allow CUDIMM DD5 to run at 8000+ ram speeds.
AlHill
You should look at gigabyte's qualified/tested hardware for their board.
[Fear and the desire for control are primary motivators for shadow dwellers. ]
pressed_for_time
jmitura
Thanks for the reply !
I understand that XMP is overclocking of memory and it increase risk of its demage and shorten lifespan - i can live with it but doas it additionally lead to shorter lifespan of cpu and other components?
pressed_for_time
I have run Intel motherboards for year with XMP enabled without any issues.
NextLevelSimGaming
I have Kingston Renegade Fury 8400m/t CUDIMM RAM, and get the rated speed on XMP Tweaked on the Asus Z890 Strix Gaming Wi-Fi F Motherboard, I would imagine the same would apply for your Gigabyte Board
