16813 Discussions
i3-350m running hot
Hello folks,
I've got an HP Probook 6450b. Wonderful machine, but it's running hot. Right now, on Win7 x64, it's idling at 49d (Celsius), which is fine. But I just did some Windows updating, and immediately afterward the dotnets went into their Optimization routines. For maybe fifteen minutes the processor was running at 25% capacity (according to Task Manager), and that drove the temps up to 85d.
The history of this machine is that it was dropped, causing some cosmetic damage to the left-front corner of the palmrest. I don't know if that's relevant. When I got the machine it shut down a couple of times, so finally I took it apart. I found that a very sloppy attempt had been made to re-paste the processor. So I redid that half an hour ago, and here I am. The case is still semi-open, allowing for plenty of airflow (though that might work against cooling the heatsink via the fan, eh?)
Essentially I've got a machine that is great at low load, but very fragile at higher load. As soon as the load increases, the fan revs up more than I would expect. It hasn't shut down yet, since the re-paste.
My question is this: do you think this is a problem that would be solved by a processor replacement, or is there something else I should consider? I'd appreciate some perspective here. Thanks much.
FGonz6
New Contributor III
Hello paul1149,
Our recommendation will be to make sure that the thermal material was correctly added to the CPU die and check if the performance of your laptop fan is properly cooling down your unit.
Please have in mind that what Intel considers a critical or dangerous temperature is anything beyond the 100 °C.
FGonz6
New Contributor III
Hello paul1149,
Thanks, Freddy. I had already done that, to no avail. The machine was shutting itself down in the mid 80d C range, so the critical temperature determination was out of my control. The repair was beyond me so I sold the unit distressed.
Be well.
FGonz6
New Contributor III
Hello Paul1149,
Thanks for the update on this. Please let me know if you need something else.
