- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi!
Im about to buy a new processor. I found the i5-8400 and then the i5-9400F which is cheaper and has same performance. The i5-8400 cointains some features (which the i5-9400F not contains) like...
Embedded Options Available
Intel® vPro™ Platform Eligibility
Intel® TSX-NI
Intel® Stable Image Platform Program (SIPP)
Intel® Trusted Execution Technology
I would like to use this CPU for video, sound and photo editing, corel draw, AutoCAD. Are these features influence the performance and important? Or not noticeable? I know, the 9400F has no integrated GPU.
Thank you for the answer!
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
There really is not much different between the two, except for the absence of graphics on the i5-9400F. Since you are not going to use the onboard graphics, the choice is yours. Personally, I would go with the i5-9400F, as it is newer and thus the warranty would be longer.
https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=190883,126687
Now, if you are planning on using an existing motherboard that supports the socket needed, you MUST also verify with the manufacturer of the board if THEIR BIOS supports either processor FIRST.
Doc
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Mostly, I worry about the TSX-NI feature. It is built in the i5-8600. What about the i5-9400F and i5-8600? The i5-8600 has the TSX-NI and the 9400F has not. Is it important for the performace?
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
These features are all a part of VPro technology, which is aimed at corporate environments and enhanced platform manageability. For your personal needs, you do not need any of these features (and none of them will make a difference to performance). Bottom line, I agree with Al; go with the 9th gen processor.
