AXI4 DMA Master Error
Manprocoder
新手
6,364 次查看
Hi expert,
I am building SoC system that includes components as follows:
+ CPU
+ onchip_memory_2_0
+ onchip_memory_2_1 (source address)
+ onchip_memory_2_2 (destination address)
+ IP (Active Ascon) has AXI4 DMAC
As program runs at simulation mode,  read burst request runs well, but write burst always encounters problem (awready is always "0" logic level), so DMAC always wait slave, leading
my system to be stuck.
Could you clarify it to me? Thanks you so much.
标签 (1)
0 项奖励
24 回复数
ScottW_Altera
员工
5,908 次查看
Hi @Manprocoder,
Could you provide some more details such as Quartus version and board/platform you are building for?
Manprocoder
新手
5,870 次查看
I provide some additionals as follows:
+ quartus lite 18.1
+ board De10 standard (5CSXFC6D6F31C6)
0 项奖励
Manprocoder
新手
5,843 次查看
Hi experts,
I provide additional details (waveform and C code) to facilitate your supports.
+Quartus Version: Quartus Prime Lite 18.1
+Board: 5CSXFC6D6F31C6 (DE10 Standard)
As I mentioned READ BURST request runs well (handshake arvalid & arready)
Read Waveform:
But WRITE BURST request always encounter problem (no handshake awvalid & awready)
Write Waveform:
C code program:
0 项奖励
ScottW_Altera
员工
5,770 次查看
Thanks for the details @Manprocoder.
From what I can see the platform design looks OK and the NIOS appears to be doing what it should to initialize the DMA so I would conclude the problem is likely to be with the active_ascon IP. I will see if I can get someone from the AXI team to take a look and give some guidance. It will likely require sharing more information about the active_ascon IP block.
0 项奖励
Manprocoder
新手
5,738 次查看
Hi @Scot
I provide overall details about active_ascon IP
Allow me to mention my issue again: WRITE BURST is being refused by slave (onchip_memory2_2)
1. Block Diagram
* Function of partial blocks
 + RD_CRF: store config (DMAC config + ASCON config) read from source memory and generate info for WR_REQUEST block
+ STORE_CKN_AD: store those data such as: ascon config, KEY, NONCE, AD, TEXT, TAG (using fifo)
+ FORMAT_DATA: format data read from source memory to run ASCON function (ASCON is algorithm that includes AEAD & HASH)
+ other remaining blocks: function is clearly presented through their name.
2. Data Frame & Timing Diagram
- Data frame (stored in source memory)
- Timing Diagram
3. WR REQUEST BLOCK
- WR_BURST GENERATOR RTL CODE
*Note: I only use information as follows
+ size: 3'b010 (always write 1 word (4 bytes) each transfer)
+ burst: 2'b01 (only use INCR burst)
0 项奖励
Manprocoder
新手
5,703 次查看
Allow me to update WR_REQUEST block.
Exact block I am using below:
0 项奖励
Manprocoder
新手
5,734 次查看
Hi @ScottW_Altera
I provide additional details on signals of active_ascon IP in platform designer.
- System with Platform Designer Interconnect
0 项奖励
ScottW_Altera
员工
5,588 次查看
Thank you for the comprehensive overview of the IP in question @Manprocoder
I am trying to find you some help internally as this isn't my area of expertise and nothing is jumping out at me from what you have posted. Hopefully others in the community may also be able to offer some advice.
Seems obvious but I will ask anyway. I am assuming the onchip memory is configured as RAM and not ROM?
Manprocoder
新手
5,570 次查看
Thanks for your attention @ScottW_Altera
My problem is too hard for me to address it, and now, I'm totally beat.
Definitely, I have to rewrite DMAC with AVALON bus.
0 项奖励
SueC_Altera
员工
5,537 次查看
Hi Manprocoder,
We checked internally, and we don't have expertise on the active_asconIP, so we aren't able to help.  I hope there is community help available.  Have you checked with the owner of the IP?
Sue
0 项奖励
Manprocoder
新手
5,520 次查看
Hi @SueC,
I do not think the problem lies in my IP.
I rewrite DMAC with Avalon bus and everything is well during run-time duration.
So, I state that interconnect does not support AXI4 burst (quartus 18.1).
0 项奖励
SueC_Altera
员工
5,406 次查看
Hi Manprocoder,
I checked with engineering and they checked the code base for 18.1 interconnect modules and found that AXI4 does support the burst logic as described in the 18.1 UG: https://www.intel.com/content/www/us/en/docs/programmable/683364/18-1/burst-support.html
Please help me understand why you think the problem is in the interconnect?
Sue
Manprocoder
新手
5,284 次查看
Hi @SueC_Altera
To be completely upfront, the reasons why I conclude my issue that lies in the interconnect are as follows:
+ The first reason: I rewrite DMAC with Avalon bus, everything is well (read and write occur smoothly)
+ The second one:  AXI4 DMAC runs well with READ burst, but the same does not happen to WRITE burst. (My IP issues request, AWVALID is active)
I only assume my problem like this, but I'm not sure 100%.
0 项奖励
SueC_Altera
员工
5,208 次查看
Hi Manprocoder,
Are you able to provide your design for us to look at?
Sue
0 项奖励
Manprocoder
新手
5,175 次查看
0 项奖励
SueC_Altera
员工
4,907 次查看
Thanks, Manprocoder. We'll get back to you.
Sue
BoonBengT_Altera
主持人
4,306 次查看
Hi @Manprocoder,
This it to let you know that we are still working on your request.
Will get back to you at earliest.
Thank you so much for your patients.
Best Wishes
BB
0 项奖励
Manprocoder
新手
4,206 次查看
Hi @BoonBengT_Altera
To be completely upfront, I have struggled to find a solution to my issue for 2 weeks before posting it to your forum. But, now, I have no time for it, so, I must turn into Avalon bus.
Thanks for your energetic support and enthusiasm.
Best wishes,
Man
0 项奖励
BoonBengT_Altera
主持人
3,213 次查看
Hi @Manprocoder,
Good to know and appreciate you sharing your updates from your end.
Hi @SueC_Altera,
Just checking in if there is any updates from your end.
Hope to hear from you soon.
Best Wishes
BB
0 项奖励
SueC_Altera
员工
3,157 次查看
Hi Manprocoder,
I've asked our engineering team to look at this issue.  We tried running your design in simulation and it got hung with no awvalid or arvalid asserted. They then created a separate design that uses the AXI4 1x1 bridge with Interconnect (Data width: 32b to 64b) and HDL generated in Quartus18.1std. Everything worked fine in this design.
I'm asking to see if we can share this design with you.
Sue
0 项奖励
回复
