공지
Abstract Classes in Nios C++
명예로운 기여자 II
1,304 조회수
I am trying to implement abstract classes using gnupro C++ for nios and cyclone.
Comparing the results using inheritance - and doing wrong - and the virtual keyword - and doing right - in the same code, the code which uses virtual keyword is 15 times bigger.
Does anyone have done something optimized using abstract classes in Nios?
Flavio
0 포인트
1 응답
명예로운 기여자 II
507 조회수
I assume by "abstract classes" you mean classes with pure virtual methods (e.g. virtual int foo() = 0).
If you are linking with libstdc++, it could be that a large chunk of exception handling code is being included (I&#39;ve found operator new & delete particularly bad for this and always override them). Have a look at your linker map (if you&#39;re not generating one, add "-Map <filename>" to your linker flags) for any evidence of this. Compiler options "-fno-exceptions" and "-fno-rtti" help greatly in keeping EC++ code size down (assuming you&#39;re not actually using exceptions and run-time type info!).
The code for virtual classes will be bigger due their vtables etc, but not by a factor of 15 (unless the non-virtual ones were very small and numerous).
If your classes really are abstract, try stubbing out the "__cxa_pure_virtual()" function as follows:
extern "C" void __cxa_pure_virtual()
Steve.
0 포인트
응답
