If there are two masters which access one slave,what happend can be?
is there any setting to setup which master is first or second?Link Copied
Hi suway1219,
> If there are two masters which access one slave,what happend can be? > > is there any setting to setup which master is first or second? Read the section entitled "Arbitration for Multi-Master Systems" in the Quartus II Handbook, Volume 4: "SOPC Builder". It will probably answer your questions. Regards, --Scott- Mark as New
--- Quote Start --- originally posted by smcnutt@Apr 13 2006, 03:09 PM hi suway1219,
> if there are two masters which access one slave,what happend can be?
read the section entitled "arbitration for multi-master systems" in the
quartus ii handbook, volume 4: "sopc builder". it will probably answer your
questions.
regards,
--scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14347)
--- quote end ---
--- Quote End --- Thank you very much!
