12746 Discussions
Can't open uart in uClinux with MMU
Hi~
Right now, I am using uClinux with MMU.
My system have 3 uart, however, My system can't see all uarts.
He always show 2.
Moreover, in ternimal, it shows I have this device, but I can't open it.
http://i37.tinypic.com/ifx405.jpg
This picture is my setting about uart
http://i36.tinypic.com/244tu0x.jpg
Is there any other select I need to change.
Do I need to change config.c inside arch/nios2/board folder?
Thanks in advance for your help.
Tingming
Maybe you need /dev/ttyS2, /dev/ttyS3...:D
Kazu
Hi Kazu:
I don't get it, why I need /dev/ttyS2 and S3?
I have 3 uart in my system, but it only show 2.
And I can't open (ttyS0 and ttyS1) in software.
Thank you very much for reply me.
--- Quote Start ---
--- Quote End ---
Please check that your UART names are well-defined in the file 'nios2-linux/linux-2.6/arch/nios2/kernel/config.c', and if not, please modify it. In default, those must be 'UART0. 'UART1', 'UART2' and 'UART3'.
/* * Altera UART */ static struct altera_uart_platform_uart nios2_uart_platform = {# if defined(UART0_BASE) || defined(UART_BASE) # ifdef UART0_BASE { .mapbase = UART0_BASE, .irq = UART0_IRQ, .uartclk = UART0_FREQ, }, # else { .mapbase = UART_BASE, .irq = UART_IRQ, .uartclk = UART_FREQ, }, # endif# endif# ifdef UART1_BASE { .mapbase = UART1_BASE, .irq = UART1_IRQ, .uartclk = UART1_FREQ, },# endif# ifdef UART2_BASE { .mapbase = UART2_BASE, .irq = UART2_IRQ, .uartclk = UART2_FREQ, },# endif# ifdef UART3_BASE { .mapbase = UART3_BASE, .irq = UART3_IRQ, .uartclk = UART3_FREQ, },# endif {}, }; And UART devices are probed in the function 'altera_uart_probe' of the file 'nios2-linux/linux-2.6/drivers/serial/altuart.c'.
static int __devinit altera_uart_probe(struct platform_device *pdev) { struct altera_uart_platform_uart *platp = pdev->dev.platform_data; struct uart_port *port; int i; for (i = 0; ((i < CONFIG_SERIAL_ALTERA_UART_MAXPORTS) && (platp.mapbase)); i++) { port = &altera_uart_ports.port; port->line = i; port->type = PORT_ALTERA_UART; port->mapbase = platp.mapbase; port->membase = ioremap(port->mapbase, ALTERA_UART_SIZE); port->iotype = SERIAL_IO_MEM; port->irq = platp.irq; port->uartclk = platp.uartclk; port->ops = &altera_uart_ops; port->flags = ASYNC_BOOT_AUTOCONF; uart_add_one_port(&altera_uart_driver, port); } return 0; } Please debug it by 'printk', if necessry. Anyway you must distinguish your UART devices by major and minor numbers, so you need /dev/ttyS2 and /dev/ttyS3 after your 4 UARTs are probed successfully.
Kazu
Hi Kazu~
Thank you very much!
My UART (S0 S1)can work already.
Now, I am trying to make S2 work.
I use mknod /dev/ttyS2 c 4 66, and my ttyS2 can work now
I didn't change config.c files, so I can't use my UART.
Thank you again for solving my problems.
TingMing.
Thanks in advance if you can shine light to the UART problem I am having. Like the problem you are having, I can't open the port or communicate to it, and I have name all my port with 'UART0. 'UART1', 'UART2' and 'UART3' in my QSYS and my device tree DTS file. The uClinux ver 3.1 boot up detect there is a UART with correct base address and irq:
ttyAL0 at MMIO 0x8100160 (irq =5) is a Altera UART
ttyAL1 at MMIO 0x8100180 (irq =6) is a Altera UART
ttyAL2 at MMIO 0x8100200 (irq =7) is a Altera UART
ttyAL3 at MMIO 0x8100220 (irq =8) is a Altera UART
ttyAL4 at MMIO 0x8100240 (irq =9) is a Altera UART
ttyAL5 at MMIO 0x8100260 (irq =10) is a Altera UART
The /dev have ttyAL0 in it, but not none of the other ports. I'm able to open and communicate with ttyAL0, but none other port. Is there something I have to do specially for the device tree or driver I have to change? I did look at the altera_uart.c and can't figure out the problem.
--- Quote Start ---
Kazu
--- Quote End ---
