- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
can Signal Tap II logic Analyzer be used for data acquisition at both rising and falling edge of the clock? I need it for test purpose. I am using TSE MAC in RGMII mode. When I put Signal Tap logic II analyzer, I have data only at one edge(not both rising and falling edge). Is there any additional setting in Signal Tap II logic Analyzer which has to be done for data acquisition at both rising and falling edge of the clock? Any help?링크가 복사됨
1 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I think by doubling frequency of sample clock being used in Signal Tap analyzer you can achieve your goal. I mean using PLL, generate one clock having frequency double than what you are using currently and use that PLL output as sampling clock in signal tap. Cheers, Bhaumik
