12748 Discussions
Error when compiling application for ethernet
Hi All,
I am trying to develop an application for ethernet device. I am using open core device driver which comes with uCLinux.
To open an ethernet device i need to get a structure named net_device which is defined into netdevice.h. After including file netdevice.h and compiling application there are following errors displayed.
In file included from
D:/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_0.1.0/include/linux/netdevice.h:28,
from test.c:3:
D:/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_0.1.0/include/linux/if.h:136: error: field `ifru_addr' has incomplete type
D:/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_0.1.0/include/linux/if.h:137: error: field `ifru_dstaddr' has incomplete type
D:/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_0.1.0/include/linux/if.h:138: error: field `ifru_broadaddr' has incomplete type
D:/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_0.1.0/include/linux/if.h:139: error: field `ifru_netmask' has incomplete type
D:/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_0.1.0/include/linux/if.h:140: error: field `ifru_hwaddr' has incomplete type
test.c:6: warning: return type defaults to `int'
test.c: In function `main':
test.c:9: error: storage size of `dev' isn't known
test.c:14: warning: implicit declaration of function `write'
test.c:9: warning: unused variable `dev'
test.c:16:2: warning: no newline at end of file
make: *** [test.o] Error 1
make: Target `all' not remade because of errors.
Here is the part of my application code..
# include<stdio.h># include<fcntl.h># include<linux/netdevice.h>
main()
int i,j=0;
const char* buf="hello";
struct net_device dev;
Can anybody suggest anything for this? Thanks in advance.
