Flash Programmer error
There always is a problem with my board while I use the Flash programmer download my software project into the Flash.
the problem is:
Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00
Resetting and pausing target processor: OK
: Checksumming existing contents
00000000 : Reading existing contents
Checksummed/read 57kB in 2.4s
00000000 ( 0%): Erasing
Erased 128kB in 0.6s (213.3kB/s)
00000000 ( 0%): Programming
assertion "m_state == STATE_DEBUG" failed: file "nios2oci.cpp", line 237
Signal 6
But,I had download my software project into the Flash twice.
Who can help me?
Tenglong
From the error message, I'd say it's quite likely you have signal integrity issues somewhere on your JTAG chain and/or a poor quality cable. It's recommended to have a USB Blaster Rev. C or better.
Good luck!
- slacker
Thank you slacker
Yes,you're right. It is a poor quality cable,while made by myself. I have deal with it. Thank you very much.
tenglong
