Hello everyone:
I encountered a strange problem during the SOPC Builder generate process. I added a component "DM9000A"(Provided in DE2's kit) to the component library and then added one instance to my system. But SOPC Builder(Quartus 5.0 SP2) can't generate it, while the SOPC Builder of quartus 6.0 can generate it succesfully(That's why I call it strange,But I have do my project with 5.0..). Dose anybody know why?Looking forward to your reply,Thanks! Below is the error information: *************************************************************************# 2007.03.22 10:38:41 (*) Running Generator Program for dm9000a_0 ERROR: In object '' of class e_port: can't access `vhdl_record_type' field known fields are: _AUTOLOAD_ACCEPT_ALL __is_inout _creation_history _direction _export _negated _never_export _object_list _parent_set _project_set _ptf_written _signal_list comment copied declare_one_bit_as_std_logic_vector default_value depth indent isa_dummy name paragraph trimmed type vhdl_declare_only_type vhdl_default width known pointers are: _parent _project keys: _AUTOLOAD_ACCEPT_ALL _permitted _pointers by the way, this object is a dummy Error: Generator program for module 'dm9000a_0' did NOT run successfully. ************************************************************Link Copied
Topic Options
